소개
The hard drive can be an easy replacement with just following a few short steps provided in this guide. The only pre requisite needed to replace the hard drive is how to take off the front cover. This is one of the easier guides to complete with the ASUS X502CA with only a few simple steps and you will be on your way with a new hard drive for your laptop.
필요한 것
Use the Phillips #00 screwdriver to remove the seven 90mm screws.
Use the Phillips #00 screwdriver to remove the four 50mm screws.
Remove the four 5mm screws that attach the hard drive bracket using the Phillips #0 screwdriver.
다른 한 분이 해당 안내서를 완성하였습니다.
