주요 콘텐츠로 건너뛰기
ASUS X502CA Hard Drive Replacement
필요한 것
  1. ASUS X502CA Hard Drive Replacement, Palm Rest with Keyboard and Touch Pad: 1 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver to remove the seven 90mm screws.
    • Use the Phillips #00 screwdriver to remove the four 50mm screws.
  2. ASUS X502CA Hard Drive Replacement: 2 단계, 이미지 1/1
    • Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. ASUS X502CA Hard Drive Replacement: 3 단계, 이미지 1/2 ASUS X502CA Hard Drive Replacement: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
  4. ASUS X502CA Hard Drive Replacement: 4 단계, 이미지 1/2 ASUS X502CA Hard Drive Replacement: 4 단계, 이미지 2/2
    • Lift Palm Rest away.
    • Replace with new palm rest.
  5. ASUS X502CA Hard Drive Replacement, Hard Drive: 5 단계, 이미지 1/2 ASUS X502CA Hard Drive Replacement, Hard Drive: 5 단계, 이미지 2/2
    • Remove the four 5mm screws that attach the hard drive bracket using the Phillips #0 screwdriver.
  6. ASUS X502CA Hard Drive Replacement: 6 단계, 이미지 1/2 ASUS X502CA Hard Drive Replacement: 6 단계, 이미지 2/2
    • Lift the hard drive and attached bracket up and out.
  7. ASUS X502CA Hard Drive Replacement: 7 단계, 이미지 1/3 ASUS X502CA Hard Drive Replacement: 7 단계, 이미지 2/3 ASUS X502CA Hard Drive Replacement: 7 단계, 이미지 3/3
    • Remove the four 5mm Phillips #0 screws attaching the bracket to the hard drive.
    • There are 2 screws on each side.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Christian Spencer
회원 가입일: 11/06/18
436 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S5-G6, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G6, Gulbrandsen Fall 2018 회원
UMASSD-GULBRANDSEN-F18S5G6
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 427
