주요 콘텐츠로 건너뛰기
ASUS X502CA Left I/O Board Replacement
필요한 것
  1. ASUS X502CA Left I/O Board Replacement, Palm Rest with Keyboard and Touch Pad: 1 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver to remove the seven 90mm screws.
    • Use the Phillips #00 screwdriver to remove the four 50mm screws.
  2. ASUS X502CA Left I/O Board Replacement: 2 단계, 이미지 1/1
    • Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. ASUS X502CA Left I/O Board Replacement: 3 단계, 이미지 1/2 ASUS X502CA Left I/O Board Replacement: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
  4. ASUS X502CA Left I/O Board Replacement: 4 단계, 이미지 1/2 ASUS X502CA Left I/O Board Replacement: 4 단계, 이미지 2/2
    • Lift Palm Rest away.
    • Replace with new palm rest.
  5. ASUS X502CA Left I/O Board Replacement, Left I/O Board: 5 단계, 이미지 1/2 ASUS X502CA Left I/O Board Replacement, Left I/O Board: 5 단계, 이미지 2/2
    • Locate the I/O board on the left of the computer. Using the Phillips #0 screwdriver, unscrew the three 5mm screws to unhinge the screen, which will free the board allowing it to be removed and replaced.
    • Be careful with handling your computer while one side is unhinged; mishandling or over pressuring the other hinge could cause damage to it or the screen.
  6. ASUS X502CA Left I/O Board Replacement: 6 단계, 이미지 1/2 ASUS X502CA Left I/O Board Replacement: 6 단계, 이미지 2/2
    • Unplug the power strip connecting to the motherboard with your fingers or plastic opening tool.
    • Make sure the power strip is disconnected before pulling the board out.
  7. ASUS X502CA Left I/O Board Replacement: 7 단계, 이미지 1/2 ASUS X502CA Left I/O Board Replacement: 7 단계, 이미지 2/2
    • Slightly pull the unhinged screen up to free the board and remove it.
결론
Christian Spencer
회원 가입일: 11/06/18
436 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S5-G6, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G6, Gulbrandsen Fall 2018 회원
UMASSD-GULBRANDSEN-F18S5G6
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 201
