소개
The keyboard and touch pad are contained within the palm rest. If you are experiancing problems with the keyboard or the touch pad and need to replace one of them, you will need to replace the entire palm rest with keyboard and touch pad.
Use the Phillips #00 screwdriver to remove the seven 90mm screws.
Use the Phillips #00 screwdriver to remove the four 50mm screws.
다른 5명이 해당 안내서를 완성하였습니다.
