주요 콘텐츠로 건너뛰기
ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement
필요한 것
  1. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement, Palm Rest with Keyboard and Touch Pad: 1 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver to remove the seven 90mm screws.
    • Use the Phillips #00 screwdriver to remove the four 50mm screws.
  2. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: 2 단계, 이미지 1/1
    • Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: 3 단계, 이미지 1/2 ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
  4. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: 4 단계, 이미지 1/2 ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: 4 단계, 이미지 2/2
    • Lift Palm Rest away.
    • Replace with new palm rest.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Michael Morrow
회원 가입일: 03/03/15
258 평판
안내서 1개 작성함
Clemson, Team 14-1, Shirley Winter 2015 Clemson, Team 14-1, Shirley Winter 2015 회원
CLEM-SHIRLEY-W15S14G1
5 회원들
안내서 5개 작성하였습니다
댓글 한 개
there is no reason to disassemble the top-half of the laptop.
seanwilson684 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 1,922
