소개
If the laptop screen takes a big hit the webcam wires can sometimes become disconnected. If the wires have become dislodged then the webcam can be fixed relatively easily by reconnecting the cables to the webcam. If the webcam breaks, the only option is to replace the webcam.
필요한 것
Remove the trim from the top of the monitor by using the Plastic Opening Tool to carefully pop off the clips around the parameter.
다른 3명이 해당 안내서를 완성하였습니다.
