소개
The display monitor is an output device which presents data on the screen. It is what allows the user to see what inputs they are putting into the device.
필요한 것
Flip open the laptop with the screen facing towards you.
Using the plastic opening tool, remove the square tape from the marked locations.
Use the Phillips #0 Screwdriver to remove the two 2mm screws from those locations.
거의 끝나갑니다!
결론
