주요 콘텐츠로 건너뛰기
ASUS X552LAV-BBI5N08 Hard Drive Replacement
필요한 것
  1. ASUS X552LAV-BBI5N08 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Battery is not showed in pictures.
    • Flip the laptop face down.
  2. ASUS X552LAV-BBI5N08 Hard Drive Replacement: 2 단계, 이미지 1/3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: 2 단계, 이미지 2/3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: 2 단계, 이미지 3/3
    • Slide the right button to the left.
    • Hold the left button to the right.
    • While you hold the left button in position, slide the battery out by pushing it away from you.
  3. ASUS X552LAV-BBI5N08 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/1
    • Start by flipping the laptop face down.
    • Locate the bottom panel. It is at the opposite end of the battery.
    • Remove the two 12mm screws at the bottom panel with a Tri-wing Y1 screwdriver.
  4. ASUS X552LAV-BBI5N08 Hard Drive Replacement: 4 단계, 이미지 1/3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: 4 단계, 이미지 2/3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: 4 단계, 이미지 3/3
    • Remove bottom panel by lifting it up.
    • Locate the hard drive.
    • It is located in the bottom left corner.
  5. ASUS X552LAV-BBI5N08 Hard Drive Replacement: 5 단계, 이미지 1/3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: 5 단계, 이미지 2/3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: 5 단계, 이미지 3/3
    • Remove the four 5.5mm screws located on the hard drive case using a Tri-wing Y1 screwdriver.
    • Slide the hard drive out to the left.
  6. ASUS X552LAV-BBI5N08 Hard Drive Replacement: 6 단계, 이미지 1/2 ASUS X552LAV-BBI5N08 Hard Drive Replacement: 6 단계, 이미지 2/2
    • Lift the hard drive out.
    • Once the hard drive is removed, place the hard drive at a different area.
  7. ASUS X552LAV-BBI5N08 Hard Drive Replacement: 7 단계, 이미지 1/3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: 7 단계, 이미지 2/3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: 7 단계, 이미지 3/3
    • Place the hard drive on its side.
    • Remove the four 5mm screws from the sides of the case by using a Tri-wing Y1 screwdriver.
    • Lift the hard drive out of the case.
결론
Jason Vo
회원 가입일: 02/15/18
857 평판
안내서 5개 작성하였습니다
USF Tampa, Team S17-G1, Boczar Spring 2018 USF Tampa, Team S17-G1, Boczar Spring 2018 회원
USFT-BOCZAR-S18S17G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 14
전체 시간: 299
