주요 콘텐츠로 건너뛰기
ASUS ZenPad S 8.0 Front Facing Camera Replacement
필요한 것
  1. ASUS ZenPad S 8.0 Front Facing Camera Replacement, Rear Cover Removal: 1 단계, 이미지 1/3 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Rear Cover Removal: 1 단계, 이미지 2/3 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Rear Cover Removal: 1 단계, 이미지 3/3
    • if present, remove the MicroSD card before disassembly. Failure to remove could lead to damage to the MicroSD card , rear cover, or MicroSD card slot.
    • Use the plastic tool to pry between the silver bezel and the back case
    • Work the tool around the device to free the back case
  2. ASUS ZenPad S 8.0 Front Facing Camera Replacement: 2 단계, 이미지 1/2 ASUS ZenPad S 8.0 Front Facing Camera Replacement: 2 단계, 이미지 2/2
    • Remove the ribbon cables by lifting up the white retaining flap on the ZIF connectors, then pulling the ribbon cable away.
    • Do not kink the ribbon cables as they can break easily
  3. ASUS ZenPad S 8.0 Front Facing Camera Replacement: 3 단계, 이미지 1/3 ASUS ZenPad S 8.0 Front Facing Camera Replacement: 3 단계, 이미지 2/3 ASUS ZenPad S 8.0 Front Facing Camera Replacement: 3 단계, 이미지 3/3
    • Remove the battery connector by prying it up away from the device using 2 plastic pry tools
  4. ASUS ZenPad S 8.0 Front Facing Camera Replacement: 4 단계, 이미지 1/2 ASUS ZenPad S 8.0 Front Facing Camera Replacement: 4 단계, 이미지 2/2
    • Remove all 9 of the 1.5mm #00 Philips screws
    • Gently lift the battery out of the device
    • Use an opening pick or similar tool to separate the adhesive on the bottom and top of the battery.
  5. ASUS ZenPad S 8.0 Front Facing Camera Replacement, Front Facing Camera: 5 단계, 이미지 1/3 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Front Facing Camera: 5 단계, 이미지 2/3 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Front Facing Camera: 5 단계, 이미지 3/3
    • Use a plastic opening tool to lift the black retaining flap on the ZIF Connector
  6. ASUS ZenPad S 8.0 Front Facing Camera Replacement: 6 단계, 이미지 1/1
    • Use a tweezers to lift out the camera
    • If you lifted the latch for the ribbon cable then it should come out with little resistance.
결론
John Astfanous
회원 가입일: 10/04/16
987 평판
안내서 3개 작성하였습니다
USF Tampa, Team 2-2, Cagle Fall 2016 USF Tampa, Team 2-2, Cagle Fall 2016 회원
USFT-CAGLE-F16S2G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 4
전체 시간: 1,333
