주요 콘텐츠로 건너뛰기
ASUS ZenPad S 8.0 Motherboard Replacement
필요한 것
  1. ASUS ZenPad S 8.0 Motherboard Replacement, Rear Cover Removal: 1 단계, 이미지 3개 중 1개 ASUS ZenPad S 8.0 Motherboard Replacement, Rear Cover Removal: 1 단계, 이미지 3개 중 2개 ASUS ZenPad S 8.0 Motherboard Replacement, Rear Cover Removal: 1 단계, 이미지 3개 중 3개
    • if present, remove the MicroSD card before disassembly. Failure to remove could lead to damage to the MicroSD card , rear cover, or MicroSD card slot.
    • Use the plastic tool to pry between the silver bezel and the back case
    • Work the tool around the device to free the back case
  2. ASUS ZenPad S 8.0 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 ASUS ZenPad S 8.0 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the ribbon cables by lifting up the white retaining flap on the ZIF connectors, then pulling the ribbon cable away.
    • Do not kink the ribbon cables as they can break easily
  3. ASUS ZenPad S 8.0 Motherboard Replacement: 3 단계, 이미지 3개 중 1개 ASUS ZenPad S 8.0 Motherboard Replacement: 3 단계, 이미지 3개 중 2개 ASUS ZenPad S 8.0 Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the battery connector by prying it up away from the device using 2 plastic pry tools
  4. ASUS ZenPad S 8.0 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 ASUS ZenPad S 8.0 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Remove all 9 of the 1.5mm #00 Philips screws
    • Gently lift the battery out of the device
    • Use an opening pick or similar tool to separate the adhesive on the bottom and top of the battery.
  5. ASUS ZenPad S 8.0 Motherboard Replacement, Front Facing Camera: 5 단계, 이미지 3개 중 1개 ASUS ZenPad S 8.0 Motherboard Replacement, Front Facing Camera: 5 단계, 이미지 3개 중 2개 ASUS ZenPad S 8.0 Motherboard Replacement, Front Facing Camera: 5 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to lift the black retaining flap on the ZIF Connector
  6. ASUS ZenPad S 8.0 Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use a tweezers to lift out the camera
    • If you lifted the latch for the ribbon cable then it should come out with little resistance.
  7. ASUS ZenPad S 8.0 Motherboard Replacement, Motherboard: 7 단계, 이미지 2개 중 1개 ASUS ZenPad S 8.0 Motherboard Replacement, Motherboard: 7 단계, 이미지 2개 중 2개
    • Using the plastic prying tool, lift the small retaining flap on the ZIF Connectors holding the ribbon cables to the motherboard
    • The removing of the ribbon cable is done in the same way as the front facing camera.
  8. ASUS ZenPad S 8.0 Motherboard Replacement: 8 단계, 이미지 3개 중 1개 ASUS ZenPad S 8.0 Motherboard Replacement: 8 단계, 이미지 3개 중 2개 ASUS ZenPad S 8.0 Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using the tweezers remove the connector gently from the yellow slot
    • Gently peel up the tape until is is completely released from the motherboard
  9. ASUS ZenPad S 8.0 Motherboard Replacement: 9 단계, 이미지 2개 중 1개 ASUS ZenPad S 8.0 Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    • Cut the warranty tape connecting the motherboard to the metal plate under the battery
  10. ASUS ZenPad S 8.0 Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Using the #00 Phillips head screwdriver, remove the remaining 1.5mm screws in the motherboard
  11. ASUS ZenPad S 8.0 Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Gently lift the motherboard from your device
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jessica Voss
회원 가입일: 10/04/16
319 평판
안내서 1개를 작성함
USF Tampa, Team 2-2, Cagle Fall 2016 USF Tampa, Team 2-2, Cagle Fall 2016 회원
USFT-CAGLE-F16S2G2
4 회원들
안내서 5개를 작성함
댓글 2개
Where can I buy a spare motherboard for this device.
Partha Tripathy - 답글
Where are the motherboard sold and how do I purchase micro USB ports
Xibu Zhang - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 2,677
