주요 콘텐츠로 건너뛰기
ASUS ZenPad S 8.0 Speakers Replacement
필요한 것
  1. ASUS ZenPad S 8.0 Speakers Replacement, Rear Cover Removal: 1 단계, 이미지 1/3 ASUS ZenPad S 8.0 Speakers Replacement, Rear Cover Removal: 1 단계, 이미지 2/3 ASUS ZenPad S 8.0 Speakers Replacement, Rear Cover Removal: 1 단계, 이미지 3/3
    • if present, remove the MicroSD card before disassembly. Failure to remove could lead to damage to the MicroSD card , rear cover, or MicroSD card slot.
    • Use the plastic tool to pry between the silver bezel and the back case
    • Work the tool around the device to free the back case
  2. ASUS ZenPad S 8.0 Speakers Replacement: 2 단계, 이미지 1/2 ASUS ZenPad S 8.0 Speakers Replacement: 2 단계, 이미지 2/2
    • Remove the ribbon cables by lifting up the white retaining flap on the ZIF connectors, then pulling the ribbon cable away.
    • Do not kink the ribbon cables as they can break easily
  3. ASUS ZenPad S 8.0 Speakers Replacement: 3 단계, 이미지 1/3 ASUS ZenPad S 8.0 Speakers Replacement: 3 단계, 이미지 2/3 ASUS ZenPad S 8.0 Speakers Replacement: 3 단계, 이미지 3/3
    • Remove the battery connector by prying it up away from the device using 2 plastic pry tools
  4. ASUS ZenPad S 8.0 Speakers Replacement: 4 단계, 이미지 1/2 ASUS ZenPad S 8.0 Speakers Replacement: 4 단계, 이미지 2/2
    • Remove all 9 of the 1.5mm #00 Philips screws
    • Gently lift the battery out of the device
    • Use an opening pick or similar tool to separate the adhesive on the bottom and top of the battery.
  5. ASUS ZenPad S 8.0 Speakers Replacement, Front Facing Camera: 5 단계, 이미지 1/3 ASUS ZenPad S 8.0 Speakers Replacement, Front Facing Camera: 5 단계, 이미지 2/3 ASUS ZenPad S 8.0 Speakers Replacement, Front Facing Camera: 5 단계, 이미지 3/3
    • Use a plastic opening tool to lift the black retaining flap on the ZIF Connector
  6. ASUS ZenPad S 8.0 Speakers Replacement: 6 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use a tweezers to lift out the camera
    • If you lifted the latch for the ribbon cable then it should come out with little resistance.
  7. ASUS ZenPad S 8.0 Speakers Replacement, Motherboard: 7 단계, 이미지 1/2 ASUS ZenPad S 8.0 Speakers Replacement, Motherboard: 7 단계, 이미지 2/2
    • Using the plastic prying tool, lift the small retaining flap on the ZIF Connectors holding the ribbon cables to the motherboard
    • The removing of the ribbon cable is done in the same way as the front facing camera.
  8. ASUS ZenPad S 8.0 Speakers Replacement: 8 단계, 이미지 1/3 ASUS ZenPad S 8.0 Speakers Replacement: 8 단계, 이미지 2/3 ASUS ZenPad S 8.0 Speakers Replacement: 8 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using the tweezers remove the connector gently from the yellow slot
    • Gently peel up the tape until is is completely released from the motherboard
  9. ASUS ZenPad S 8.0 Speakers Replacement: 9 단계, 이미지 1/2 ASUS ZenPad S 8.0 Speakers Replacement: 9 단계, 이미지 2/2
    • Cut the warranty tape connecting the motherboard to the metal plate under the battery
  10. ASUS ZenPad S 8.0 Speakers Replacement: 10 단계, 이미지 1/1
    • Using the #00 Phillips head screwdriver, remove the remaining 1.5mm screws in the motherboard
  11. ASUS ZenPad S 8.0 Speakers Replacement: 11 단계, 이미지 1/1
    • Gently lift the motherboard from your device
  12. ASUS ZenPad S 8.0 Speakers Replacement, Daughter Board: 12 단계, 이미지 1/3 ASUS ZenPad S 8.0 Speakers Replacement, Daughter Board: 12 단계, 이미지 2/3 ASUS ZenPad S 8.0 Speakers Replacement, Daughter Board: 12 단계, 이미지 3/3
    • To remove the ribbon cables, lift up the white retaining flap on the ZIF Connectors with a plastic pry tool
  13. ASUS ZenPad S 8.0 Speakers Replacement: 13 단계, 이미지 1/3 ASUS ZenPad S 8.0 Speakers Replacement: 13 단계, 이미지 2/3 ASUS ZenPad S 8.0 Speakers Replacement: 13 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using the tweezers gently pull off the tape over the ribbon cable
  14. ASUS ZenPad S 8.0 Speakers Replacement: 14 단계, 이미지 1/2 ASUS ZenPad S 8.0 Speakers Replacement: 14 단계, 이미지 2/2
    • Using the tweezers gently pull the ribbon cable out from from the connector.
  15. ASUS ZenPad S 8.0 Speakers Replacement: 15 단계, 이미지 1/3 ASUS ZenPad S 8.0 Speakers Replacement: 15 단계, 이미지 2/3 ASUS ZenPad S 8.0 Speakers Replacement: 15 단계, 이미지 3/3
    • Using the tweezers gently remove the connector from the yellow slot
  16. ASUS ZenPad S 8.0 Speakers Replacement: 16 단계, 이미지 1/2 ASUS ZenPad S 8.0 Speakers Replacement: 16 단계, 이미지 2/2
    • Cut the warranty tape connecting the daughter board to the metal plate under the battery
  17. ASUS ZenPad S 8.0 Speakers Replacement: 17 단계, 이미지 1/3 ASUS ZenPad S 8.0 Speakers Replacement: 17 단계, 이미지 2/3 ASUS ZenPad S 8.0 Speakers Replacement: 17 단계, 이미지 3/3
    • Using the #00 Phillips head screwdriver, remove the remaining 1.5mm screws in the daughter board
    • Gently lift the daughter board from the device
  18. ASUS ZenPad S 8.0 Speakers Replacement, Speakers: 18 단계, 이미지 1/2 ASUS ZenPad S 8.0 Speakers Replacement, Speakers: 18 단계, 이미지 2/2
    • Gently lift up the speaker to remove it from the device
  19. ASUS ZenPad S 8.0 Speakers Replacement: 19 단계, 이미지 1/3 ASUS ZenPad S 8.0 Speakers Replacement: 19 단계, 이미지 2/3 ASUS ZenPad S 8.0 Speakers Replacement: 19 단계, 이미지 3/3
    • Using the #00 Phillips head screwdriver, remove the 1.5mm screws
    • Gently lift up the second speaker to remove it from the device
결론
John Astfanous
회원 가입일: 10/04/16
987 평판
안내서 3개 작성하였습니다
USF Tampa, Team 2-2, Cagle Fall 2016 USF Tampa, Team 2-2, Cagle Fall 2016 회원
USFT-CAGLE-F16S2G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 976
