주요 콘텐츠로 건너뛰기
ASUS ZenWatch Battery Replacement
필요한 것
  1. ASUS ZenWatch Battery Replacement, Watch Strap Removal: 1 단계, 이미지 1/2 ASUS ZenWatch Battery Replacement, Watch Strap Removal: 1 단계, 이미지 2/2
    • On the strap there is a knob. Sliding this knob towards the opposite side of the strap releases the tension on the spring bar, allowing you to pull the strap out..
  2. ASUS ZenWatch Battery Replacement, Battery: 2 단계, 이미지 1/3 ASUS ZenWatch Battery Replacement, Battery: 2 단계, 이미지 2/3 ASUS ZenWatch Battery Replacement, Battery: 2 단계, 이미지 3/3
    • Use the T5 Torx driver to remove the four screws on the case.
    • Use the magnetic pad to keep all your parts easily contained!
    • The case will pry easily off with just gentle hand pressure
  3. ASUS ZenWatch Battery Replacement: 3 단계, 이미지 1/2 ASUS ZenWatch Battery Replacement: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using the tweezers, gently remove the fabric protecting the battery connection.
    • Take care when removing the fabric. Too much force may damage the contact with the metal tweezers.
    • Use the heavy duty spudger to gently push the contact towards the top of the case.
  4. ASUS ZenWatch Battery Replacement: 4 단계, 이미지 1/3 ASUS ZenWatch Battery Replacement: 4 단계, 이미지 2/3 ASUS ZenWatch Battery Replacement: 4 단계, 이미지 3/3
    • Gently pry the battery up with the plastic pry tools
결론
다른 13명이 해당 안내서를 완성하였습니다.
Wayne McClure
회원 가입일: 02/10/16
961 평판
안내서 5개 작성하였습니다
USF Tampa, Team 1-3, Sullivan Spring 2016 USF Tampa, Team 1-3, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S1G3
4 회원들
안내서 7개 작성하였습니다
댓글 5개
Where could i find the modul replacement for asus zenwatch edition (1st editio) the chip body…thanks :) Dave
Davy Jones - 답글
Dónde puedo adquirir esta batería en Colombia
Jhon Jairo Piza Puerta - 답글
I want to find a battery for zenwatch 1 plz help i still have a fully functioning zenwatch I don’t want to waste it. (pref na or even better Canadian the shipping is murder)
wing_0_delta - 답글
Hi
im looking for a battery für Asus Viviwatch. Is ist the same as in ZenWatch?
mhoechtl - 답글
Looking to get zenwatch 1 battery. Any source recommended by anyone?
fine_pears - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 26
전체 시간: 13,910
