주요 콘텐츠로 건너뛰기
ASUS ZenWatch Charging Cradle Circuit board Replacement
필요한 것
  1. ASUS ZenWatch Charging Cradle Circuit board Replacement, Charging Cradle Circuit board: 1 단계, 이미지 3개 중 1개 ASUS ZenWatch Charging Cradle Circuit board Replacement, Charging Cradle Circuit board: 1 단계, 이미지 3개 중 2개 ASUS ZenWatch Charging Cradle Circuit board Replacement, Charging Cradle Circuit board: 1 단계, 이미지 3개 중 3개
    • Using a metal spudger gently pry the plastic outer case apart
    • Pry open a little bit on each side before trying to open fully
  2. ASUS ZenWatch Charging Cradle Circuit board Replacement: 2 단계, 이미지 3개 중 1개 ASUS ZenWatch Charging Cradle Circuit board Replacement: 2 단계, 이미지 3개 중 2개 ASUS ZenWatch Charging Cradle Circuit board Replacement: 2 단계, 이미지 3개 중 3개
    • Use the PH0 sized Phillips screwdriver to remove the three screws (2mm) holding the board to the cradle.
    • Gently pry up with your hands to pull the board off.
    • Don't grab directly on the USB port as you may loosen or bust the connections.
결론
작성자
2다른 기여자 명과 함께
Wayne McClure
회원 가입일: 02/10/16
961 평판
안내서 5개를 작성함
USF Tampa, Team 1-3, Sullivan Spring 2016 USF Tampa, Team 1-3, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S1G3
4 회원들
안내서 7개를 작성함
1가이드 댓글
If you had listed what components were on the board or at least taken a picture of the other side of the board, I might have given you some points.
Nate Fansler - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 5
지난 30일: 13
전체 시간: 3,029
