소개
Step-by-step guide in removing and replacing a faulty motherboard.
필요한 것
On the strap there is a knob. Sliding this knob towards the opposite side of the strap releases the tension on the spring bar, allowing you to pull the strap out..
Use the T5 Torx driver to remove the four screws on the case.
The case will pry easily off with just gentle hand pressure
다른 3명이 해당 안내서를 완성하였습니다.
댓글 한 개
Where could i get the new replacement motherboard for that? Please inform.. thanks :)
Davy Jones - 답글
