주요 콘텐츠로 건너뛰기
AT&T CL4940 Number Pad Replacement and Cleaning
필요한 것
  1. AT&T CL4940 Number Pad Replacement and Cleaning, Number Pad: 1 단계, 이미지 2개 중 1개 AT&T CL4940 Number Pad Replacement and Cleaning, Number Pad: 1 단계, 이미지 2개 중 2개
    • Unplug your device before beginning disassembly.
    • Remove the phone line from the back cover of the device.
    • Remove the power cord from the side of the device.
    • Remove the phone cable from the side of the device.
  2. AT&T CL4940 Number Pad Replacement and Cleaning: 2 단계, 이미지 1개 중 1개
    • Remove the five 4mm X 10mm screws from the back cover of the device using a Phillips #1 screwdriver.
  3. AT&T CL4940 Number Pad Replacement and Cleaning: 3 단계, 이미지 3개 중 1개 AT&T CL4940 Number Pad Replacement and Cleaning: 3 단계, 이미지 3개 중 2개 AT&T CL4940 Number Pad Replacement and Cleaning: 3 단계, 이미지 3개 중 3개
    • Using a metal spudger, pry the white, plastic cover from the gray, plastic bottom. Start from below the keypad and work your way evenly around the device.
    • There are brackets every few inches along the edge of the device. These may be difficult to pull apart.
    • The internals of the device will be accessible once the white, plastic cover and grey, plastic bottom are separated.
  4. AT&T CL4940 Number Pad Replacement and Cleaning: 4 단계, 이미지 3개 중 1개 AT&T CL4940 Number Pad Replacement and Cleaning: 4 단계, 이미지 3개 중 2개 AT&T CL4940 Number Pad Replacement and Cleaning: 4 단계, 이미지 3개 중 3개
    • Remove the five 5mm X 5mm screws located on the yellow side of the motherboard using a Phillips #1 screwdriver.
    • Set the motherboard out of the way.
  5. AT&T CL4940 Number Pad Replacement and Cleaning: 5 단계, 이미지 3개 중 1개 AT&T CL4940 Number Pad Replacement and Cleaning: 5 단계, 이미지 3개 중 2개 AT&T CL4940 Number Pad Replacement and Cleaning: 5 단계, 이미지 3개 중 3개
    • Remove the two 5mm X 8mm large number pad screws using a Phillips #1 screwdriver.
    • Remove the 5mm X 6mm latch screw using the same screwdriver.
    • Remove the small, metal latch.
    • Remove the plastic plate previously secured by the screws and latch.
  6. AT&T CL4940 Number Pad Replacement and Cleaning: 6 단계, 이미지 3개 중 1개 AT&T CL4940 Number Pad Replacement and Cleaning: 6 단계, 이미지 3개 중 2개 AT&T CL4940 Number Pad Replacement and Cleaning: 6 단계, 이미지 3개 중 3개
    • Remove the remaining six 5mm X 8mm large number pad screws using a Phillips #1 screwdriver.
    • Remove the two 3mm X 6mm small number pad screws using the same screwdriver.
    • Grab the edge of the number pad board and peel it away from the screw posts.
    • Using a clean towel or cloth, move the number pad board away from the keys that lie below.
    • Set the number pad board out of the way for further disassembly.
  7. AT&T CL4940 Number Pad Replacement and Cleaning: 7 단계, 이미지 2개 중 1개 AT&T CL4940 Number Pad Replacement and Cleaning: 7 단계, 이미지 2개 중 2개
    • Peel away the white, rubber mat and set it aside for cleaning.
    • Remove the main key pad and any remaining keys. Remember where each key is located for reassembly.
    • Clean the rubber mat with a damp paper towel to remove any dust or foreign substances.
    • Replace any broken or cracked keys.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Nigel Mathias
회원 가입일: 02/16/16
215 평판
안내서 1개를 작성함
IUPUI, Team 2-2, Harley Spring 2016 IUPUI, Team 2-2, Harley Spring 2016 회원
IUPUI-HARLEY-S16S2G2
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 9
지난 30일: 20
전체 시간: 690
