주요 콘텐츠로 건너뛰기
AT-LP60X Belt Installation
필요한 것
  1. AT-LP60X Belt Installation, Setup: 1 단계, 이미지 3개 중 1개 AT-LP60X Belt Installation, Setup: 1 단계, 이미지 3개 중 2개 AT-LP60X Belt Installation, Setup: 1 단계, 이미지 3개 중 3개
    • Disconnect the power from the turntable.
    • Raise the dust cover.
  2. AT-LP60X Belt Installation, Removing Platter: 2 단계, 이미지 2개 중 1개 AT-LP60X Belt Installation, Removing Platter: 2 단계, 이미지 2개 중 2개
    • Remove the slipmat from the platter.
    • Pull the platter off by lifting vertically from the two circular holes.
  3. AT-LP60X Belt Installation, Mount The Belt To Platter: 3 단계, 이미지 1개 중 1개
    • Locate the belt.
    • Flip the platter upside-down and place the belt around the inner ring of the platter.
  4. AT-LP60X Belt Installation, Mounting Platter and Belt: 4 단계, 이미지 3개 중 1개 AT-LP60X Belt Installation, Mounting Platter and Belt: 4 단계, 이미지 3개 중 2개 AT-LP60X Belt Installation, Mounting Platter and Belt: 4 단계, 이미지 3개 중 3개
    • Place the platter back on the center spindle.
    • Spin the platter such that the gold pulley of the motor is showing.
    • Stretch the belt from the platter around the gold pulley of the motor.
  5. AT-LP60X Belt Installation, Preform Mechanical Reset: 5 단계, 이미지 3개 중 1개 AT-LP60X Belt Installation, Preform Mechanical Reset: 5 단계, 이미지 3개 중 2개 AT-LP60X Belt Installation, Preform Mechanical Reset: 5 단계, 이미지 3개 중 3개
    • Place the slipmat back onto the platter, and press the STOP button.
    • Using your right hand, secure the tone arm in place.
    • [OPTIONAL] Use a twist tie and the built in hook.
    • While the tone arm is secured, use your left hand to slowly spin the platter 10 times clockwise.
    • You should hear a few clicks and pops.
  6. AT-LP60X Belt Installation, Reconnect Power: 6 단계, 이미지 1개 중 1개
    • Remove the twist tie if used to secure the tone arm from Step 5.
    • Reconnect the power supply.
    • The belt installation procedure is now complete - you are ready to try a record!
  7. AT-LP60X Belt Installation, Common Mistakes: 7 단계, 이미지 2개 중 1개 AT-LP60X Belt Installation, Common Mistakes: 7 단계, 이미지 2개 중 2개
    • Any twists while installing the belt will cause improper operation.
    • The belt should NOT be connected to this white post.
    • The belt should NOT be connected to the base of the turntable.
    • The belt should ONLY make contact with the bottom of the platter and the gold pulley of the motor.
결론
If this guide does not fix the issue of the platter not spinning, the following issues could be present:
  1. Faulty AC Adaptor - Can be purchased here.
  2. Faulty Diode (D01) - Requires soldering (repair guide can be provided upon request: service@atus.com). Part Number: 576-SMAJ13A
  3. Faulty Motor - Requires soldering (repair guide can be provided upon request: service@atus.com). Part Number: 704-F706-7303
To send your turntable in for service, please follow the necessary steps from our website.
Feel free to contact one of our technicians for further assistance at (330)686-2600 ext.5004
다른 2명이 해당 안내서를 완성하였습니다.
첨부 문서
작성자
1다른 기여자 명과 함께
Anthony @ ATUS
회원 가입일: 02/28/19
1,195 평판
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 55
지난 30일: 259
전체 시간: 2,062
