주요 콘텐츠로 건너뛰기
ATT CL4940 Internal Microphone Replacement
필요한 것
  1. ATT CL4940 Internal Microphone Replacement, Internal Microphone: 1 단계, 이미지 2개 중 1개 ATT CL4940 Internal Microphone Replacement, Internal Microphone: 1 단계, 이미지 2개 중 2개
    • Unplug your device before beginning disassembly.
    • Remove the phone line and the power cord from the back of the device.
    • Remove the phone cable from the side of the device.
  2. ATT CL4940 Internal Microphone Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the five 4mm X 10mm Phillips head screws from the back cover of the device.
  3. ATT CL4940 Internal Microphone Replacement: 3 단계, 이미지 3개 중 1개 ATT CL4940 Internal Microphone Replacement: 3 단계, 이미지 3개 중 2개 ATT CL4940 Internal Microphone Replacement: 3 단계, 이미지 3개 중 3개
    • Starting from the bottom of the device, (using a metal spudger) separate the top (white) plastic piece from the bottom (gray) plastic piece.
    • Work your way across the bottom of the device, then to each side, and finally to the top.
    • There are brackets every few inches along the edge of the device. These may be difficult to pull apart.
    • The top and bottom pieces should separate, and the internals of the device will now be accessible.
  4. ATT CL4940 Internal Microphone Replacement: 4 단계, 이미지 1개 중 1개
    • Using wire cutters, sever both the red and the black wires connected to the microphone.
    • To remove the microphone from the device, gently wiggle it while pulling it apart.
결론
작성자
3다른 기여자 명과 함께
Charles Moore
회원 가입일: 02/16/16
201 평판
안내서 2개를 작성함
IUPUI, Team 2-2, Harley Spring 2016 IUPUI, Team 2-2, Harley Spring 2016 회원
IUPUI-HARLEY-S16S2G2
4 회원들
안내서 8개를 작성함
1가이드 댓글
I'd rather install a new microphone instead of just reinstalling the old one.
Is there a link to where a new microphone can be purchased?
rpoland - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 24
전체 시간: 822
