주요 콘텐츠로 건너뛰기
ATT EL52300 Battery Replacement
  1. ATT EL52300 Battery Replacement, Battery: 1 단계, 이미지 1/2 ATT EL52300 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Find the bump where the battery cover meets the phone. Put your thumb here, and push and slide the cover down.
  2. ATT EL52300 Battery Replacement: 2 단계, 이미지 1/1
    • Unplug the battery by squeezing your hands on the small white plug and lifting it up.
    • Do not pull on the wire itself because you might damage the wire!
    • The battery is now detached and ready to be removed by lifting it out.
결론
Katty
회원 가입일: 08/27/15
313 평판
안내서 3개 작성하였습니다
USF Tampa, Team 1-1, Sullivan Spring 2016 USF Tampa, Team 1-1, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S1G1
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 9
전체 시간: 860
