주요 콘텐츠로 건너뛰기
ATT Trek HD 9020A Screen Replacement
필요한 것
  1. ATT Trek HD 9020A Screen Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • To separate the screen from the back panel, run the plastic opening tool along the outer edge of the device.
  2. ATT Trek HD 9020A Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the screen away from the back panel.
  3. ATT Trek HD 9020A Screen Replacement, Battery: 3 단계, 이미지 2개 중 1개 ATT Trek HD 9020A Screen Replacement, Battery: 3 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to remove the six 2.5 mm screws located around the perimeter of the battery.
  4. ATT Trek HD 9020A Screen Replacement: 4 단계, 이미지 2개 중 1개 ATT Trek HD 9020A Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to disconnect the black battery connector.
    • Gently lift the battery out of the device.
  5. ATT Trek HD 9020A Screen Replacement, Motherboard: 5 단계, 이미지 2개 중 1개 ATT Trek HD 9020A Screen Replacement, Motherboard: 5 단계, 이미지 2개 중 2개
    • Using a Phillips #00 screwdriver, remove the seven 1 mm screws on the green perimeter of the motherboard.
  6. ATT Trek HD 9020A Screen Replacement: 6 단계, 이미지 2개 중 1개 ATT Trek HD 9020A Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to disconnect the large gold strip underneath the metal plate from the motherboard.
  7. ATT Trek HD 9020A Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to disconnect the front and back cameras from motherboard.
  8. ATT Trek HD 9020A Screen Replacement: 8 단계, 이미지 2개 중 1개 ATT Trek HD 9020A Screen Replacement: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    $3.99
    • Use angled tweezers to pry up the black tab.
    • Use the angled tweezers to pull out the gold connector.
  9. ATT Trek HD 9020A Screen Replacement: 9 단계, 이미지 2개 중 1개 ATT Trek HD 9020A Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Use the angled tweezers to disconnect the gold connector.
  10. ATT Trek HD 9020A Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to disconnect the black connectors on each side of the motherboard.
  11. ATT Trek HD 9020A Screen Replacement: 11 단계, 이미지 2개 중 1개 ATT Trek HD 9020A Screen Replacement: 11 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to lift the motherboard out of place.
  12. ATT Trek HD 9020A Screen Replacement, Front Camera: 12 단계, 이미지 2개 중 1개 ATT Trek HD 9020A Screen Replacement, Front Camera: 12 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    $3.99
  13. ATT Trek HD 9020A Screen Replacement, Screen: 13 단계, 이미지 3개 중 1개 ATT Trek HD 9020A Screen Replacement, Screen: 13 단계, 이미지 3개 중 2개 ATT Trek HD 9020A Screen Replacement, Screen: 13 단계, 이미지 3개 중 3개
    • Use the Phillips #00 screwdriver to remove the six 3 mm screws holding the black plastic corner pieces in place.
    • Gently lift the black corner pieces out of the device.
  14. ATT Trek HD 9020A Screen Replacement: 14 단계, 이미지 2개 중 1개 ATT Trek HD 9020A Screen Replacement: 14 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    $3.99
    • Use the angled tweezers to remove the black cables on each side of the device from their groove.
  15. ATT Trek HD 9020A Screen Replacement: 15 단계, 이미지 2개 중 1개 ATT Trek HD 9020A Screen Replacement: 15 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to disconnect the black cable connectors from each side of the device.
  16. ATT Trek HD 9020A Screen Replacement: 16 단계, 이미지 2개 중 1개 ATT Trek HD 9020A Screen Replacement: 16 단계, 이미지 2개 중 2개
    • Remove the remaining ten 3 mm Phillips #00 screws.
  17. ATT Trek HD 9020A Screen Replacement: 17 단계, 이미지 2개 중 1개 ATT Trek HD 9020A Screen Replacement: 17 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to disconnect the remaining three gold connectors at the bottom of the device.
  18. ATT Trek HD 9020A Screen Replacement: 18 단계, 이미지 2개 중 1개 ATT Trek HD 9020A Screen Replacement: 18 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to pry up the grey plastic panel.
  19. ATT Trek HD 9020A Screen Replacement: 19 단계, 이미지 2개 중 1개 ATT Trek HD 9020A Screen Replacement: 19 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to pry the screen out of the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Jacob Cross
회원 가입일: 01/16/19
475 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 13
전체 시간: 785
