소개
This guide will first show you how to disassemble the interior of a Corolla 2010 to get to the AUX input. Then we are going to locate the component to be soldered (but be EXTRA CAREFUL when you solder).
필요한 것
Don't be afraid to use extra force to get these components to open.
1) There is two side of the component to remove for the first picture
Before removing component in the third picture, there are two screws to be removed (one on each side).
Pull the component out in the first picture with force!
Reach underneath the white component connected to wire and along there, push to remove it from the AUX component (black rectangle thing)
Once the white component detached, simply push AUX component out (toward you).
Thank you so much I just fixed my aux on my 2009 camry. Same issue where it would not stay on aux option it would go directly to radio. Appreciate it so much!
Apply pressure where the toothpick is pointing and remove the cap at the same time. (Can get tricky)
Finally, like the third picture, remove the AUX circuit with force but try to be gentle also.
The center pin is located where the red circle is at on the picture
The pins are the pointy things. The red circle doesn't actually show the pins but it is close. Make sure you put solder on the pins and not the pre-existing solder. This might sound dumb to some, but the first time I did this I soldered the old solder instead of soldering the pins because I had no soldering and electronics experience. I thought that it would cause electricity to bridge between them. Not only does the solder need to cover each pin, but both pins needs to be inside the same solder bubble.
Hold the soldering gun in one hand and the solder in another. Lightly touch them together where the pin is shown in previous step.
Soldering does not have to be perfect as long as it connects the two pin we located in the previous picture.
Insert wisdom here.
Before you put everything back together you should test that the aux port now works as intended. You can do this by plugging the port in without putting the panel back on. Then connect your aux device and try to play music or something. Whole the music is playing disconnect the aux wire from the car. The car's radio should remain on aux mode even though there is no longer a device connected. If it switches modes it means that you did not solder the aux pins correctly. After this you can reassemble everything. If you want to be extra cautious you can check all other electrical components that you may have had to disconnect (like a cigarette lighter) before putting all the panels back on.
Hopefully this guide will save you time if done correctly and will definitely save you money. Local Toyota shop will charge over $100 just for an inspection and that doesn't include repairing the AUX input.
다른 11명이 해당 안내서를 완성하였습니다.
댓글 13개
nice descriptions you could also wrap aluminum foil around the two middle prongs if you do not own or know how to solder
Gary Stone - 답글
Hello Gary,
How would wrap aluminum foil around it? I mean how would you stick it to the pins so it doesn’t fall?
You are the man! This is perfect, it defeats the automatic change source when the cable is removed thing. I think what was happening is that the contacts on the plug got old and dirty and the radio was seeing very short disconnections, like a millisecond and was thinking that the cable was removed and switching inputs. This mod makes the radio think that the cable is always plugged in so it stays on the aux input, it's the way the radio should have been designed. The aux connection stays stable and it works perfectly, everyone should do this mod!
Much appreciated! I was getting so frustrated with this issue, very glad you put this guide together. I had some trouble trying to remove the AUX circuit from it’s protective housing, but then realized you don’t need to. So I pulled it out just enough to solder the 2 pins then put it right back in.
I just soldered the two contacts mentioned on the aux input of my 2007 Rav4 and this fixed the selecting problem and made the quality of sound better! Thanks for the info!
Worked GREAT!!!! Like one of the others said, I didn’t have to remove the PCB from the housing because the end that needed solder was already visible. I did the mechanical and my college sophomore daughter did the soldering. Easy Peesy Japaneasy!!!!!! This Aux input had been an intermittent problem for my daughter for quite sometime. BTW….her car is a 2009 Corolla.
Thanks again.
Paul and Nicole
What is the “white component” that connects to the back of the aux port? Thats the part I need and no one knows where to order it from
