주요 콘텐츠로 건너뛰기
AUX-208P1 Electric Kettle Temperature Controller Replacement
필요한 것
  1. AUX-208P1 Electric Kettle Temperature Controller Replacement, Temperature Controller: 1 단계, 이미지 1/2 AUX-208P1 Electric Kettle Temperature Controller Replacement, Temperature Controller: 1 단계, 이미지 2/2
    • Clean all the dirt on the bottom of the electric kettle.
  2. AUX-208P1 Electric Kettle Temperature Controller Replacement: 2 단계, 이미지 1/2 AUX-208P1 Electric Kettle Temperature Controller Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the three 19 mm screws at the bottom of the electric kettle.
    • Remove the base of the electric kettle.
    • Remove the LED indicator buckled on the base.
  3. AUX-208P1 Electric Kettle Temperature Controller Replacement: 3 단계, 이미지 1/2 AUX-208P1 Electric Kettle Temperature Controller Replacement: 3 단계, 이미지 2/2
    • Use combination pliers to clamp the connection between the electric kettle line and the old temperature controller to create a gap, and pull it off.
    • Don't use too much force to avoid damage to the line!
  4. AUX-208P1 Electric Kettle Temperature Controller Replacement: 4 단계, 이미지 1/1
    • Use combination pliers to remove the nuts holding down the old temperature controller.
  5. AUX-208P1 Electric Kettle Temperature Controller Replacement: 5 단계, 이미지 1/2 AUX-208P1 Electric Kettle Temperature Controller Replacement: 5 단계, 이미지 2/2
    • Remove the broken temperature controller.
    • Clean the bottom of the kettle to remove any dust or debris buildup.
  6. AUX-208P1 Electric Kettle Temperature Controller Replacement: 6 단계, 이미지 1/1
    • Align the socket on the bottom of the new temperature controller with the protrusion on the bottom of the electric kettle to assemble.
  7. AUX-208P1 Electric Kettle Temperature Controller Replacement: 7 단계, 이미지 1/1
    • Use combination pliers to reinstall the nuts holding down the temperature controller.
  8. AUX-208P1 Electric Kettle Temperature Controller Replacement: 8 단계, 이미지 1/1
    • Fasten the electric kettle circuit to the contact reed of the new temperature controller.
    • Gently pull the interface to ensure a firm installation.
  9. AUX-208P1 Electric Kettle Temperature Controller Replacement: 9 단계, 이미지 1/2 AUX-208P1 Electric Kettle Temperature Controller Replacement: 9 단계, 이미지 2/2
    • Re-buckle the removed LED indicator back to the base.
    • Buckle the base back to the bottom of the electric kettle.
    • Use a Phillips #0 screwdriver to three 19 mm screws on the bottom of the kettle.
결론
重新组装设备时,请依次相反的拆卸顺序。
다른 한 분이 해당 안내서를 완성하였습니다.
SHAN HUANG
회원 가입일: 01/13/21
193 평판
안내서 2개 작성하였습니다
York University, Team S1-G30, O'Regan Winter 2021 York University, Team S1-G30, O'Regan Winter 2021 회원
YORK-O'REGAN-W21S1G30
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 46
전체 시간: 1,309
