주요 콘텐츠로 건너뛰기
AYL SoundFit Battery Replacement
필요한 것
  1. AYL SoundFit Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the four hex screws on the top of the device using a 2.5 hex screwdriver.
  2. AYL SoundFit Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Place a spudger between the black plastic cover and the green case.
    • Pry the black cover away from the main casing and remove the cover.
  3. AYL SoundFit Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Place a spudger between the black housing, which contains the woofer, and the outer rubber casing.
    • Pry the housing away from the body to reveal the motherboard, speaker, and battery.
  4. AYL SoundFit Battery Replacement: 4 단계, 이미지 2개 중 1개 AYL SoundFit Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the two Phillips #00 screws securing the battery casing.
    • Remove the battery case to reveal the battery.
  5. AYL SoundFit Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Desolder the positive and negative battery contacts from the motherboard.
    • Remove the battery from the device.
결론
작성자
2다른 기여자 명과 함께
Dustin Moore
회원 가입일: 02/16/16
108 평판
안내서 1개를 작성함
IUPUI, Team 3-3, Harley Spring 2016 IUPUI, Team 3-3, Harley Spring 2016 회원
IUPUI-HARLEY-S16S3G3
4 회원들
안내서 5개를 작성함
4가이드 댓글
Which battery is this, and what is the mAH?
jlongsa - 답글
3.7V 1500mAh, 5.55Wh
Coba Farr -
The charger works but it does not say chargeing
Zaira Cortes - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 19
전체 시간: 3,054
