주요 콘텐츠로 건너뛰기
AYL SoundFit Speaker Replacement
필요한 것
  1. AYL SoundFit Speaker Replacement, Motherboard: 1 단계, 이미지 1/1
    • Unscrew the four hex screws on the top of the device using a 2.5mm hex screwdriver.
  2. AYL SoundFit Speaker Replacement: 2 단계, 이미지 1/1
    • Place a spudger between the black plastic cover and the green case.
    • Remove the black cover away from the main casing and remove the cover.
  3. AYL SoundFit Speaker Replacement: 3 단계, 이미지 1/1
    • Place the spudger tool between the black housing, which contains the woofer, and the outer rubber casing.
    • Remove the housing away from the body to reveal the motherboard, speaker, and battery.
  4. AYL SoundFit Speaker Replacement: 4 단계, 이미지 1/2 AYL SoundFit Speaker Replacement: 4 단계, 이미지 2/2
    • Remove the two Phillips screws which hold its battery casing on the housing using a PH00 Phillips screwdriver.
    • Remove the battery case to reveal the battery.
  5. AYL SoundFit Speaker Replacement: 5 단계, 이미지 1/1
    • Using a soldering iron, heat up and remove both the positive and negative battery contacts from the motherboard.
  6. AYL SoundFit Speaker Replacement: 6 단계, 이미지 1/3 AYL SoundFit Speaker Replacement: 6 단계, 이미지 2/3 AYL SoundFit Speaker Replacement: 6 단계, 이미지 3/3
    • Remove all three Phillips screws which holds the motherboard to the base using a PH00 Phillips screwdriver.
    • The motherboard can now be wiggled free from the base.
  7. AYL SoundFit Speaker Replacement, Speaker: 7 단계, 이미지 1/1
    • Using a soldering iron, heat up and remove the positive and negative wire contacts from the motherboard.
  8. AYL SoundFit Speaker Replacement: 8 단계, 이미지 1/1
    • Remove four Phillips #1 screws to detach the speaker form the module.
    • Extract the speaker from the body of the AYL SoundFit.
결론
Sajal Kherde
회원 가입일: 02/16/16
107 평판
안내서 1개 작성함
IUPUI, Team 3-3, Harley Spring 2016 IUPUI, Team 3-3, Harley Spring 2016 회원
IUPUI-HARLEY-S16S3G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 649
