필요한 것
Loosen the back cover using the suction cup.
Pull up on all four corners of the back with the suction cup.
거의 끝나갑니다!
To reassemble your device you will need to solder the wires back in position and then follow the other steps in reverse order.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
