주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Accessing Apple Cinema Display M8149 Control Boards
필요한 것
  1. Accessing Apple Cinema Display M8149 Control Boards, Control Boards: 1 단계, 이미지 3개 중 1개 Accessing Apple Cinema Display M8149 Control Boards, Control Boards: 1 단계, 이미지 3개 중 2개 Accessing Apple Cinema Display M8149 Control Boards, Control Boards: 1 단계, 이미지 3개 중 3개
    • Before starting, make sure the display is unplugged.
    • Place the Cinema Display so that it is lying on its face and the feet are pointed away from you.
    • Remove the three screws (9.52 x 4.43mm) that connect the back foot to the hinge using the Hex Key.
    • Remove the back foot from the hinge mount by grabbing the foot and pulling upwards.
  2. Accessing Apple Cinema Display M8149 Control Boards: 2 단계, 이미지 3개 중 1개 Accessing Apple Cinema Display M8149 Control Boards: 2 단계, 이미지 3개 중 2개 Accessing Apple Cinema Display M8149 Control Boards: 2 단계, 이미지 3개 중 3개
    • Remove the eighteen (5.25 x 4.43 mm) screws around the edge of the backplate using the Hex key.
    • Disconnect the small white connector leading to the display's Power button.
    • Gently lift the backplate off of the display. Completely remove the backplate and set it aside.
  3. Accessing Apple Cinema Display M8149 Control Boards: 3 단계, 이미지 2개 중 1개 Accessing Apple Cinema Display M8149 Control Boards: 3 단계, 이미지 2개 중 2개
    • Use a Phillips #2 screwdriver to remove the four (9.52 x 3.43 mm) screws on the outer rim of the metal cover.
    • Next, remove the four cover (11.91 x 2.89 mm) screws located at the corners of the metal cover using the Phillips #2 screwdriver.
  4. Accessing Apple Cinema Display M8149 Control Boards: 4 단계, 이미지 3개 중 1개 Accessing Apple Cinema Display M8149 Control Boards: 4 단계, 이미지 3개 중 2개 Accessing Apple Cinema Display M8149 Control Boards: 4 단계, 이미지 3개 중 3개
    • Unplug the large brown plug in the center-right, that connects the control board to the rest of the display.
    • Unplug the blue and gray plug on the right side of the control board. Repeat with the left side.
  5. Accessing Apple Cinema Display M8149 Control Boards: 5 단계, 이미지 2개 중 1개 Accessing Apple Cinema Display M8149 Control Boards: 5 단계, 이미지 2개 중 2개
    • Gently lift the large metal cover which spans across the back of the whole display.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
15다른 기여자 명과 함께
Brett Murphy
회원 가입일: 04/01/11
199 평판
안내서 3개를 작성함
Cal Poly, Team 10-41, Forte Spring 2011 Cal Poly, Team 10-41, Forte Spring 2011 회원
CPSU-FORTE-S11S10G41
5 회원들
안내서 18개를 작성함
1가이드 댓글
thank you for this guide. my 22" adc didn't want to start up. after following this guide, it now works with my G4. thank you
thereddrag0n - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 18
지난 30일: 72
전체 시간: 6,244
