소개
This guide will show you how to gain access to the LCD Control Board and the Backlight Control Board on an Apple Cinema Display M8149. The tools required for this section are the spudger and the PH 2 screwdriver.
도구
부품
지정된 부품이 없습니다.
Flip the Cinema Display so it is on its face and the feet are pointed away from you.
Using the PH 2 screw driver, unscrew the three feet screws (9.52 x 4.43mm).
Remove the back foot from the hinge mount by grabbing the foot and pulling upwards.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 한 개
thank you for this guide. my 22" adc didn't want to start up. after following this guide, it now works with my G4. thank you
