주요 콘텐츠로 건너뛰기
소개
If your Apple Cinema Display M8149 control board isn't sending signals, leading to system crashes, than use this guide to replace the faulty control board.
The control board is an essential part of the display as it is the component that acts as the nerve center that the CPU sends signal through, when those signals aren't being processed by the control board than that can cause the system to crash.
Before using this guide make sure to have the required tools needed to complete this guide, they will be needed from steps 1 through 3.
Before starting the steps be sure to power off the display and disconnect it from any external power source.
도구
부품
지정된 부품이 없습니다.
  1. Accessing Apple Cinema Display M8149 Control Boards, Control Boards: 1 단계, 이미지 1/3 Accessing Apple Cinema Display M8149 Control Boards, Control Boards: 1 단계, 이미지 2/3 Accessing Apple Cinema Display M8149 Control Boards, Control Boards: 1 단계, 이미지 3/3
    • Before starting, make sure the display is unplugged.
    • Place the Cinema Display so that it is lying on its face and the feet are pointed away from you.
    • Remove the three screws (9.52 x 4.43mm) that connect the back foot to the hinge using the Hex Key.
    • Remove the back foot from the hinge mount by grabbing the foot and pulling upwards.
    Mine had hex head screws instead of Phillips head.
    Bill Greene - 답글
    Hex 2.0 screws here too!
    dietrichbatista - 답글
  2. Accessing Apple Cinema Display M8149 Control Boards: 2 단계, 이미지 1/3 Accessing Apple Cinema Display M8149 Control Boards: 2 단계, 이미지 2/3 Accessing Apple Cinema Display M8149 Control Boards: 2 단계, 이미지 3/3
    • Remove the eighteen (5.25 x 4.43 mm) screws around the edge of the backplate using the Hex key.
    • Disconnect the small white connector leading to the display's Power button.
    • Gently lift the backplate off of the display. Completely remove the backplate and set it aside.
    AND: Shall we mention right here, there is a small white connector leading to the display's POWER button that should be disconnected to slide the back plate off.
    spudmcat - 답글
    These screws too were hex head, not PH2, on my display.
    Bill Greene - 답글
    Exactly: Hex 2.0 screws
  3. Accessing Apple Cinema Display M8149 Control Boards: 3 단계, 이미지 1/2 Accessing Apple Cinema Display M8149 Control Boards: 3 단계, 이미지 2/2
    • Use a Phillips #2 screwdriver to remove the four (9.52 x 3.43 mm) screws on the outer rim of the metal cover.
    • Next, remove the four cover (11.91 x 2.89 mm) screws located at the corners of the metal cover using the Phillips #2 screwdriver.
    Here and on the next step you’ll m
    need a PH 2 screwdriver
  4. Accessing Apple Cinema Display M8149 Control Boards: 4 단계, 이미지 1/3 Accessing Apple Cinema Display M8149 Control Boards: 4 단계, 이미지 2/3 Accessing Apple Cinema Display M8149 Control Boards: 4 단계, 이미지 3/3
    • Unplug the large brown plug in the center-right, that connects the control board to the rest of the display.
    • Unplug the blue and gray plug on the right side of the control board. Repeat with the left side.
  5. Accessing Apple Cinema Display M8149 Control Boards: 5 단계, 이미지 1/2 Accessing Apple Cinema Display M8149 Control Boards: 5 단계, 이미지 2/2
    • Gently lift the large metal cover which spans across the back of the whole display.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Brett Murphy
회원 가입일: 2011년 04월 01일
197 평판
안내서 3개 작성하였습니다
Cal Poly, Team 10-41, Forte Spring 2011 Cal Poly, Team 10-41, Forte Spring 2011 회원
CPSU-FORTE-S11S10G41
5 회원들
안내서 12개 작성하였습니다
One Comment
thank you for this guide. my 22" adc didn't want to start up. after following this guide, it now works with my G4. thank you
thereddrag0n - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 34
전체 시간: 5,213
