주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Accessing LCD Screen
필요한 것
  1. Accessing LCD Screen, Front and Back Cover: 1 단계, 이미지 1/2 Accessing LCD Screen, Front and Back Cover: 1 단계, 이미지 2/2
    • Remove the following screws:
    • Two silver 3.15mm Phillips #00 screws on the right side of the camera
    • Two silver 2.08mm Phillips #00 screws on the left side of the camera
  2. Accessing LCD Screen: 2 단계, 이미지 1/1
    • Remove the two indicated screws on the bottom of the camera:
    • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
    • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
  3. Accessing LCD Screen: 3 단계, 이미지 1/2 Accessing LCD Screen: 3 단계, 이미지 2/2
    • Carefully pull the back of casing away from the front.
  4. Accessing LCD Screen: 4 단계, 이미지 1/3 Accessing LCD Screen: 4 단계, 이미지 2/3 Accessing LCD Screen: 4 단계, 이미지 3/3
    • After removing the back cover, several things must be removed.
    • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
  5. Accessing LCD Screen: 5 단계, 이미지 1/2 Accessing LCD Screen: 5 단계, 이미지 2/2
    • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
  6. Accessing LCD Screen, LCD: 6 단계, 이미지 1/2 Accessing LCD Screen, LCD: 6 단계, 이미지 2/2
    • On the front of the camera, in battery case, remove screws indicated:
    • Two black 2.05mm Phillips #00 screws
  7. Accessing LCD Screen: 7 단계, 이미지 1/2 Accessing LCD Screen: 7 단계, 이미지 2/2
    • Flip the camera over to the backside and remove screws indicated:
    • The screw circled in red is a longer black 3.00mm Phillips #00 screw
    • The screw circled in red is a shorter black 2.00mm Phillips #00 screw
  8. Accessing LCD Screen: 8 단계, 이미지 1/1
    • Pull the cover plate off for the two power cord jacks.
  9. Accessing LCD Screen: 9 단계, 이미지 1/3 Accessing LCD Screen: 9 단계, 이미지 2/3 Accessing LCD Screen: 9 단계, 이미지 3/3
    • Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder.
  10. Accessing LCD Screen: 10 단계, 이미지 1/1
    • Remove the orange tape on top of the SD cardholder.
  11. Accessing LCD Screen: 11 단계, 이미지 1/3 Accessing LCD Screen: 11 단계, 이미지 2/3 Accessing LCD Screen: 11 단계, 이미지 3/3
    • Open the battery cover and lift plastic piece off.
  12. Accessing LCD Screen: 12 단계, 이미지 1/1
    • Remove tape on left side of camera.
  13. Accessing LCD Screen: 13 단계, 이미지 1/1
    • Remove the indicated 2.40mm Phillips #00 screw to release top left LCD bracket.
  14. Accessing LCD Screen: 14 단계, 이미지 1/1
    • Remove top left LCD bracket.
    • This is a small piece, be careful not to lose it.
  15. Accessing LCD Screen: 15 단계, 이미지 1/2 Accessing LCD Screen: 15 단계, 이미지 2/2
    • Push down bottom left LCD bracket to release the LCD from grip.
  16. Accessing LCD Screen: 16 단계, 이미지 1/1
    • Gently lift up LCD screen.
  17. Accessing LCD Screen: 17 단계, 이미지 1/3 Accessing LCD Screen: 17 단계, 이미지 2/3 Accessing LCD Screen: 17 단계, 이미지 3/3
    • Slowly pull LCD screen to the left to remove it from the other grips.
    • BEWARE: The LCD screen is attached to the logic board by two wires at the bottom.
결론
Bassem Tossoun
회원 가입일: 01/21/11
201 평판
안내서 2개 작성하였습니다
Cal Poly, Team 4-29, Regan Winter 2011 Cal Poly, Team 4-29, Regan Winter 2011 회원
CPSU-REGAN-W11S4G29
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 19
전체 시간: 1,030
