소개
This guide will require you to disassemble the rear and side panels of the printer in order to access the circuit board.
도구
부품
지정된 부품이 없습니다.
Remove the top hinged panel by taking out the pins at the bottom of this panel.
Remove the front panel by gently freeing the holes on the panel from the pegs attached to the main printer body one at a time. Make sure to remove the entire front panel, not just the flap on the paper tray.
다른 3명이 해당 안내서를 완성하였습니다.
