주요 콘텐츠로 건너뛰기
Accessing Samsung ML2510 Circuit Board
필요한 것
  1. Accessing Samsung ML2510 Circuit Board, Removing Samsung ML2510 Back Panel: 1 단계, 이미지 3개 중 1개 Accessing Samsung ML2510 Circuit Board, Removing Samsung ML2510 Back Panel: 1 단계, 이미지 3개 중 2개 Accessing Samsung ML2510 Circuit Board, Removing Samsung ML2510 Back Panel: 1 단계, 이미지 3개 중 3개
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Accessing Samsung ML2510 Circuit Board: 2 단계, 이미지 1개 중 1개
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Accessing Samsung ML2510 Circuit Board: 3 단계, 이미지 3개 중 1개 Accessing Samsung ML2510 Circuit Board: 3 단계, 이미지 3개 중 2개 Accessing Samsung ML2510 Circuit Board: 3 단계, 이미지 3개 중 3개
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  4. Accessing Samsung ML2510 Circuit Board, Accessing Samsung ML2510 Circuit Board: 4 단계, 이미지 3개 중 1개 Accessing Samsung ML2510 Circuit Board, Accessing Samsung ML2510 Circuit Board: 4 단계, 이미지 3개 중 2개 Accessing Samsung ML2510 Circuit Board, Accessing Samsung ML2510 Circuit Board: 4 단계, 이미지 3개 중 3개
    • Remove the front panel by gently freeing the holes on the panel from the pegs attached to the main printer body one at a time. Make sure to remove the entire front panel, not just the flap on the paper tray.
  5. Accessing Samsung ML2510 Circuit Board: 5 단계, 이미지 1개 중 1개
    • Using a Phillips #2 screwdriver, remove the two 1" screws on the front face of the printer.
  6. Accessing Samsung ML2510 Circuit Board: 6 단계, 이미지 3개 중 1개 Accessing Samsung ML2510 Circuit Board: 6 단계, 이미지 3개 중 2개 Accessing Samsung ML2510 Circuit Board: 6 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, gently lift one side of the top panel from its peg.
    • Repeat the process for the other side.
    • Lift the top panel from the front to remove it entirely.
  7. Accessing Samsung ML2510 Circuit Board: 7 단계, 이미지 3개 중 1개 Accessing Samsung ML2510 Circuit Board: 7 단계, 이미지 3개 중 2개 Accessing Samsung ML2510 Circuit Board: 7 단계, 이미지 3개 중 3개
    • Lift the right panel up from the raised stops.
    • Rotate the panel gently as indicated in the picture to remove the panel entirely.
  8. Accessing Samsung ML2510 Circuit Board: 8 단계, 이미지 1개 중 1개
    • Using a Phillips #2 screwdriver, remove the four 1" screws attaching the gray plate to the printer.
    • Remove the plastic cover by sliding it carefully under the silver hinges on the right.
  9. Accessing Samsung ML2510 Circuit Board: 9 단계, 이미지 1개 중 1개
    • Using a Phillips #2 screwdriver, remove the 1" screw attaching the circuit board to the printer.
  10. Accessing Samsung ML2510 Circuit Board: 10 단계, 이미지 2개 중 1개 Accessing Samsung ML2510 Circuit Board: 10 단계, 이미지 2개 중 2개
    • Turn over the circuit board to access main wiring.
    • Unplug the wiring from the circuit board gently.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
bbaustin
회원 가입일: 10/12/11
268 평판
안내서 6개를 작성함
Cal Poly, Team 17-18, Regan Fall 2011 Cal Poly, Team 17-18, Regan Fall 2011 회원
CPSU-REGAN-F11S17G18
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 25
전체 시간: 3,030
