주요 콘텐츠로 건너뛰기
Acer AL1714 LCD Replacement
필요한 것
  1. Acer AL1714 LCD Replacement, LCD: 1 단계, 이미지 1/2 Acer AL1714 LCD Replacement, LCD: 1 단계, 이미지 2/2
    • Turn the monitor facedown.
    • Unscrew the 5 screws holding the back cover on.
    • (This may require flipping the monitor over and shaking the screws loose once they're already unscrewed)
  2. Acer AL1714 LCD Replacement: 2 단계, 이미지 1/3 Acer AL1714 LCD Replacement: 2 단계, 이미지 2/3 Acer AL1714 LCD Replacement: 2 단계, 이미지 3/3
    • Take the edge tool or a metal ruler and insert it into the bezel.
    • Apply pressure and push down.
    • Do the same to the right side.
    • Once the side of the bezel facing you is decoupled, take the back cover and pry it loose.
    • (This will require some force, you will hear a loud popping/snapping noises)
  3. Acer AL1714 LCD Replacement: 3 단계, 이미지 1/3 Acer AL1714 LCD Replacement: 3 단계, 이미지 2/3 Acer AL1714 LCD Replacement: 3 단계, 이미지 3/3
    • Remove the Power Button Circuit Board Flat Flex Cable from the Power Supply board under the metal cover.
    • Pull the cord back and out of the way.
    • (It may be stuck down with adhesive)
  4. Acer AL1714 LCD Replacement: 4 단계, 이미지 1/3 Acer AL1714 LCD Replacement: 4 단계, 이미지 2/3 Acer AL1714 LCD Replacement: 4 단계, 이미지 3/3
    • Unscrew the cord anchors for the VGA port.
    • (Use needle nose pliers if they're too tight for removal by hand)
  5. Acer AL1714 LCD Replacement: 5 단계, 이미지 1/2 Acer AL1714 LCD Replacement: 5 단계, 이미지 2/2
    • Turn the monitor around.
    • Unscrew the 1 screw holding the Flat Power Cable cover in place.
    • Lift up and remove the Flat Power Cable cover.
    • (Careful: it may be sharp)
  6. Acer AL1714 LCD Replacement: 6 단계, 이미지 1/1
    • Unscrew the 5 screws holding the metal cage on.
  7. Acer AL1714 LCD Replacement: 7 단계, 이미지 1/2 Acer AL1714 LCD Replacement: 7 단계, 이미지 2/2
    • Lift up on the back of metal cage, slightly.
    • Pull the cage toward self.
    • (Must be careful to free cover of the VGA port and power supply input)
  8. Acer AL1714 LCD Replacement: 8 단계, 이미지 1/3 Acer AL1714 LCD Replacement: 8 단계, 이미지 2/3 Acer AL1714 LCD Replacement: 8 단계, 이미지 3/3
    • Lift up on the Flat Flex Cable holder tabs to release the cords.
    • Lift up on the Flat Flex Cables and bend them out of the working area.
  9. Acer AL1714 LCD Replacement: 9 단계, 이미지 1/3 Acer AL1714 LCD Replacement: 9 단계, 이미지 2/3 Acer AL1714 LCD Replacement: 9 단계, 이미지 3/3
    • Unplug the 4 backlight wires from their ports on the Power Supply board.
    • (Considering their size, the best way to unplug the backlight wires is by slowly jiggling and pulling the wires out of place)
  10. Acer AL1714 LCD Replacement: 10 단계, 이미지 1/1
    • Unscrew the 5 screws holding the Power Supply and Video Display boards.
  11. Acer AL1714 LCD Replacement: 11 단계, 이미지 1/2 Acer AL1714 LCD Replacement: 11 단계, 이미지 2/2
    • Lift and remove the joined Power Supply and Video Display boards.
  12. Acer AL1714 LCD Replacement: 12 단계, 이미지 1/3 Acer AL1714 LCD Replacement: 12 단계, 이미지 2/3 Acer AL1714 LCD Replacement: 12 단계, 이미지 3/3
    • Carefully detach the Power Supply and Video Display boards at the connector joint.
    • (This step is not necessary to replace the LCD Module. This step is only a safety precaution so as not to bend or break the Power Supply connector joint)
  13. Acer AL1714 LCD Replacement: 13 단계, 이미지 1/1
    • Remove the Flat Flex Cable from the Power Button Circuit board.
  14. Acer AL1714 LCD Replacement: 14 단계, 이미지 1/3 Acer AL1714 LCD Replacement: 14 단계, 이미지 2/3 Acer AL1714 LCD Replacement: 14 단계, 이미지 3/3
    • Grasp, lift, and remove the LCD Module from the front panel.
  15. Acer AL1714 LCD Replacement: 15 단계, 이미지 1/1
    • The final product with the LCD Module removed.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Christopher Kelly
회원 가입일: 09/25/14
590 평판
안내서 4개 작성하였습니다
USF Tampa, Team 1-3, Brown Fall 2014 USF Tampa, Team 1-3, Brown Fall 2014 회원
USFT-BROWN-F14S1G3
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 12
30일 전: 25
전체 시간: 1,830
