주요 콘텐츠로 건너뛰기
Acer AL1714 Power Button Circuit Board Flat Flex Cables Replacement
필요한 것
  1. Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement, Power Button Circuit Board Flat Flex Cables: 1 단계, 이미지 1/2 Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement, Power Button Circuit Board Flat Flex Cables: 1 단계, 이미지 2/2
    • Turn the monitor facedown.
    • Unscrew the 5 screws holding the back cover on.
    • (This may require flipping the monitor and shaking the screws loose once they're already unscrewed)
  2. Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: 2 단계, 이미지 1/3 Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: 2 단계, 이미지 2/3 Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: 2 단계, 이미지 3/3
    • Take the edge tool or a metal ruler and insert it into the bezel.
    • Apply pressure and push down.
    • Do the same to the right side.
    • Once side of bezel facing you is decoupled, take the back cover and pry it loose.
  3. Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: 3 단계, 이미지 1/3 Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: 3 단계, 이미지 2/3 Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: 3 단계, 이미지 3/3
    • Remove the Power Button Circuit board Flat Flex Cable from the Power Supply board under the metal cage.
    • Pull the cord back and out of the way.
    • (It may be stuck down with adhesive)
  4. Acer AL1714 Power Button Circuit Board  Flat Flex Cables Replacement: 4 단계, 이미지 1/1
    • Remove the Flat Flex Cables from the Power Button Circuit Board.
결론
Christopher Kelly
회원 가입일: 09/25/14
590 평판
안내서 4개 작성하였습니다
USF Tampa, Team 1-3, Brown Fall 2014 USF Tampa, Team 1-3, Brown Fall 2014 회원
USFT-BROWN-F14S1G3
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 7
전체 시간: 663
