이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn the monitor facedown.
Unscrew the 5 screws holding the back cover on.
Take the edge tool or a metal ruler and insert it into the bezel.
Apply pressure and push down.
Do the same to the right side.
Once the side of bezel facing you is decoupled, take the back cover and pry it loose.
Remove the Flat Flex Cable from the Power Supply Board under the metal cover.
Pull the cord back and out of the way.
Turn the monitor around.
Unscrew the 1 screw holding the Flex Power Cable cover.
Lift up and remove the Flex Power Cable cover.
Lift up on the back of the metal cage slightly.
Pull the cage toward self.
Lift up on the Flat Flex Cable holder tabs to release cords.
Lift up on the Flat Flex Cables and bend them out of the working area.
Unplug the 4 backlight wires from their ports on the Power Supply Board.
Unscrew the 5 screws holding the Power Supply Board and Video Display boards on.
Lift up and remove the joined Power Supply Board and Video Display boards.
Carefully detach the Power Supply and Video Display boards at their connector joint.
다른 3명이 해당 안내서를 완성하였습니다.
