주요 콘텐츠로 건너뛰기
Acer AL1916 Outer Case Replacement
필요한 것
  1. Acer AL1916 Outer Case Replacement, Stand: 1 단계, 이미지 1/1
    • Lay the monitor on a flat surface so that the back is facing up.
  2. Acer AL1916 Outer Case Replacement: 2 단계, 이미지 1/2 Acer AL1916 Outer Case Replacement: 2 단계, 이미지 2/2
    • Grab the hinge cover with both hands on either side of the stand.
    • Squeeze inwards with your thumbs and fingers and lift up to remove the hinge cover.
  3. Acer AL1916 Outer Case Replacement: 3 단계, 이미지 1/2 Acer AL1916 Outer Case Replacement: 3 단계, 이미지 2/2
    • Remove the four 12.1 mm Phillips #2 screws that hold the stand to the monitor.
    • Support the monitor while removing the screws to prevent the monitor from falling.
    • Lift up to detach the stand.
  4. Acer AL1916 Outer Case Replacement, Outer Case: 4 단계, 이미지 1/2 Acer AL1916 Outer Case Replacement, Outer Case: 4 단계, 이미지 2/2
    • Remove the five 9.5 mm Phillips #2 screws located around the perimeter of the monitor.
  5. Acer AL1916 Outer Case Replacement: 5 단계, 이미지 1/3 Acer AL1916 Outer Case Replacement: 5 단계, 이미지 2/3 Acer AL1916 Outer Case Replacement: 5 단계, 이미지 3/3
    • Starting at the corner of the monitor, wedge the small plastic opening tool between the back cover and the display bezel.
    • Tilt the plastic opening tool up to separate the back cover from the display bezel.
    • Continue around the perimeter of the monitor until the display bezel comes off.
    • A reasonable amount of force is necessary to detach the back cover from the display bezel.
  6. Acer AL1916 Outer Case Replacement: 6 단계, 이미지 1/2 Acer AL1916 Outer Case Replacement: 6 단계, 이미지 2/2
    • Reposition the monitor so that the back is facing up.
    • Grab the corners of the monitor and jiggle them upwards to detach the back cover from the inside of the monitor.
    • Lift the back cover up.
결론
Keith
회원 가입일: 10/06/11
351 평판
안내서 4개 작성하였습니다
Cal Poly, Team 20-26, Maness Fall 2011 Cal Poly, Team 20-26, Maness Fall 2011 회원
CPSU-MANESS-F11S20G26
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 5
전체 시간: 1,233
