주요 콘텐츠로 건너뛰기
Acer AL1916 Stand Replacement
필요한 것
  1. Acer AL1916 Stand Replacement, Stand: 1 단계, 이미지 1/1
    • Lay the monitor on a flat surface so that the back is facing up.
  2. Acer AL1916 Stand Replacement: 2 단계, 이미지 1/2 Acer AL1916 Stand Replacement: 2 단계, 이미지 2/2
    • Grab the hinge cover with both hands on either side of the stand.
    • Squeeze inwards with your thumbs and fingers and lift up to remove the hinge cover.
  3. Acer AL1916 Stand Replacement: 3 단계, 이미지 1/2 Acer AL1916 Stand Replacement: 3 단계, 이미지 2/2
    • Remove the four 12.1 mm Phillips #2 screws that hold the stand to the monitor.
    • Support the monitor while removing the screws to prevent the monitor from falling.
    • Lift up to detach the stand.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Keith
회원 가입일: 10/06/11
351 평판
안내서 4개 작성하였습니다
Cal Poly, Team 20-26, Maness Fall 2011 Cal Poly, Team 20-26, Maness Fall 2011 회원
CPSU-MANESS-F11S20G26
4 회원들
안내서 14개 작성하였습니다
댓글 한 개
Worked great…never would have guessed how to do it. Thanks.
GREG HILL - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 42
전체 시간: 20,184
