이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
The VGA input transfers information from the computer to the monitor, so having one that is working properly is important.
필요한 것
Remove the five 9.5 mm Phillips #2 screws located around the perimeter of the monitor.
Remove the two 5.7 mm Phillips #2 screws located on either side of the EMI shield.
Remove the beige control cable to the left of the VGA input by pulling it up.
Using the soldering iron, desolder the VGA input at the indicated locations.
Solder the new VGA input into the circuit board at the same locations.
Click here for more information on component-level soldering.
