주요 콘텐츠로 건너뛰기
Acer Aspire 3 A315 Screen Replacement
필요한 것
  1. Acer Aspire 3 A315 Screen Replacement, Removing the cover: 1 단계, 이미지 1/3 Acer Aspire 3 A315 Screen Replacement, Removing the cover: 1 단계, 이미지 2/3 Acer Aspire 3 A315 Screen Replacement, Removing the cover: 1 단계, 이미지 3/3
    • Alright, so the the first step is to make sure the power off for safety reasons. Carefully unhook the cover and it pops off and take it off so it's the screen itself and back cover
  2. Acer Aspire 3 A315 Screen Replacement, Unscrewing the screen from the back cover: 2 단계, 이미지 1/3 Acer Aspire 3 A315 Screen Replacement, Unscrewing the screen from the back cover: 2 단계, 이미지 2/3 Acer Aspire 3 A315 Screen Replacement, Unscrewing the screen from the back cover: 2 단계, 이미지 3/3
    • Locate the 4 screws in all corners and unscrew them. Be sure to put them separately from other screws and don't loose them!
  3. Acer Aspire 3 A315 Screen Replacement, Disconnecting the screen from the frame and camera: 3 단계, 이미지 1/3 Acer Aspire 3 A315 Screen Replacement, Disconnecting the screen from the frame and camera: 3 단계, 이미지 2/3 Acer Aspire 3 A315 Screen Replacement, Disconnecting the screen from the frame and camera: 3 단계, 이미지 3/3
    • Undo the tape from the camera wires that are taped to the back of the screen. Push the cover backward for ease to get to the screen better. Locate the 6 screws that are one the sides of the frame. 3 on each side of the frame. Unscrew them and set them to the side
  4. Acer Aspire 3 A315 Screen Replacement, Disconnecting the screen and reapplying it: 4 단계, 이미지 1/3 Acer Aspire 3 A315 Screen Replacement, Disconnecting the screen and reapplying it: 4 단계, 이미지 2/3 Acer Aspire 3 A315 Screen Replacement, Disconnecting the screen and reapplying it: 4 단계, 이미지 3/3
    • Find the cable connected to bottom of the screen. Untape it and take it off carefully to not damage it. Take the old screen off and put the new one in it. Reconnect the cable carefully and retape it to secure it
  5. Acer Aspire 3 A315 Screen Replacement, Cable management and rescrew the screen to the frame: 5 단계, 이미지 1/3 Acer Aspire 3 A315 Screen Replacement, Cable management and rescrew the screen to the frame: 5 단계, 이미지 2/3 Acer Aspire 3 A315 Screen Replacement, Cable management and rescrew the screen to the frame: 5 단계, 이미지 3/3
    • Like usual with everything, cable management. Look out for the white and black wires and make sure they are set where they are need to be ( blue arrows). Retape the camera wire to the back of the screen (green or cyan arrow). Rescrew the screen back together to the frame with the 6 small screws you removed earlier. And hold the screen in place
  6. Acer Aspire 3 A315 Screen Replacement, Resrewing screen to back cover: 6 단계, 이미지 1/3 Acer Aspire 3 A315 Screen Replacement, Resrewing screen to back cover: 6 단계, 이미지 2/3 Acer Aspire 3 A315 Screen Replacement, Resrewing screen to back cover: 6 단계, 이미지 3/3
    • Put back the 4 screws from each other the corners of the screen. The screen should be connected to the back cover and able to stand up without your support
  7. Acer Aspire 3 A315 Screen Replacement, Putting cover on and testing: 7 단계, 이미지 1/2 Acer Aspire 3 A315 Screen Replacement, Putting cover on and testing: 7 단계, 이미지 2/2
    • Snap the cover back on the screen carefully not to cause any damage. Afterwards boot it up and check its operational. Thanks for checking out my first guide! Hope it helps
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Hunter hale
회원 가입일: 03/05/23
175 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 29
30일 전: 139
전체 시간: 988
