주요 콘텐츠로 건너뛰기
Acer Aspire 3 A315-21-92FX Hard Drive Replacement
필요한 것
  1. Acer Aspire 3 A315-21-92FX Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Please make sure that there is no external access to the battery, and the battery is out of power.
    • Flip the Acer Aspire 3 A315-21-92FX over, so the back-side is oriented to the upward position.
  2. Acer Aspire 3 A315-21-92FX Hard Drive Replacement: 2 단계, 이미지 1/2 Acer Aspire 3 A315-21-92FX Hard Drive Replacement: 2 단계, 이미지 2/2
    • Remove the single 2.5mm Phillips #0 screw.
  3. Acer Aspire 3 A315-21-92FX Hard Drive Replacement: 3 단계, 이미지 1/1
    • Use the iFixit opening tool to remove the cover of the hard disk.
  4. Acer Aspire 3 A315-21-92FX Hard Drive Replacement: 4 단계, 이미지 1/2 Acer Aspire 3 A315-21-92FX Hard Drive Replacement: 4 단계, 이미지 2/2
    • Pull the hard disk out of the Acer Aspire 3 A315-21-92FX slightly and slowly.
    • This laptop is missing the hard drive.
결론
다른 4명이 해당 안내서를 완성하였습니다.
ShengKun Lu
회원 가입일: 01/14/20
705 평판
안내서 3개 작성하였습니다
York University, Team S1-G5, Woodhouse Winter 2020 York University, Team S1-G5, Woodhouse Winter 2020 회원
YORK-WOODHOUSE-W20S1G5
3 회원들
안내서 4개 작성하였습니다
댓글 2개
My acer aspire 3 A315-32 says no bootable device I had tried to boot Linux from USB but I partioned the hard drive so I fixed it by changing the format and deleting everything and installed windows on a different pc but it’s still not booting even on boot options it’s not showing
Zeek tuyishime - 답글
These connecting cable is missing, where to buy these cable. Pls tell the cable name
jayesh v v - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 22
30일 전: 96
전체 시간: 6,064
