소개
This replacement guide will show you how to replace a full or faulty hard disk drive in your Acer Aspire 3 A315-21-92FX.
Physical or logical failure of your hard disk will cause operating system crashes in your Acer Aspire 3 A315-21-92FX. Before using this guide to replace the hard disk, make sure to check the troubleshooting page for ensuring that the problem is relative with the hard disk.
필요한 것
Flip the Acer Aspire 3 A315-21-92FX over, so the back-side is oriented to the upward position.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 2개
My acer aspire 3 A315-32 says no bootable device I had tried to boot Linux from USB but I partioned the hard drive so I fixed it by changing the format and deleting everything and installed windows on a different pc but it’s still not booting even on boot options it’s not showing
These connecting cable is missing, where to buy these cable. Pls tell the cable name
jayesh v v - 답글
