주요 콘텐츠로 건너뛰기
Acer Aspire 3 A315-24P-R7VH Motherboard Replacement
필요한 것
  1. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    • Power off the machine and unplug it from the wall charger.
  2. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Close the laptop and flip it over.
    • Remove the eleven 6.5 mm Phillips screws from the lower case.
  3. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Insert an opening pick between the lower case and chassis.
    • Pry around the entire perimeter until the lower case releases.
    • Remove the lower case.
  4. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    • Optional: Put on an anti-static wrist strap. Ground yourself by connecting the metal clip at the end to any unpainted metal surface outside of the laptop.
  5. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Battery: 5 단계, 이미지 1개 중 1개
    • Grip the white battery connector and pull it directly out of its socket.
    • Do not pull on the wires.
  6. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Unscrew the four 4.5 mm Phillips head screws that secure the battery.
  7. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Lift the battery up and out of the chassis.
  8. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, SSD: 8 단계, 이미지 1개 중 1개
    • Unscrew the one 2.2 mm Phillips head screw that secures the SSD.
    • The SSD will lift to a slight angle.
  9. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Gently grasp the drive and pull it directly out of its socket.
  10. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Double check and make sure the replacement SSD is 2280 in size.
  11. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Speaker: 11 단계, 이미지 2개 중 1개 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Speaker: 11 단계, 이미지 2개 중 2개
    • Find the speakers at the bottom left and right corners of the laptop.
  12. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: 12 단계, 이미지 1개 중 1개
    • Unplug each speaker carefully.
    • There are no screws holding the speakers in place, so once unplugged, lift them out.
  13. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: 13 단계, 이미지 2개 중 1개 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: 13 단계, 이미지 2개 중 2개
    • Plug in the new speaker and place it in the corner that correlates to its shape. The speaker that is to go to the left corner of the laptop will be labeled with an L, likewise the speaker for the right will be labeled with an R.
  14. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement, Motherboard: 14 단계, 이미지 1개 중 1개
    • Disconnect the white ribbon cable from the motherboard, near the Network Interface Card, by lifting up the black locking flap then gently pulling it out of its socket.
  15. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: 15 단계, 이미지 3개 중 1개 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: 15 단계, 이미지 3개 중 2개 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: 15 단계, 이미지 3개 중 3개
    • Unscrew the three 4.5 mm screws that secure the heatsink.
  16. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: 16 단계, 이미지 3개 중 1개 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: 16 단계, 이미지 3개 중 2개 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: 16 단계, 이미지 3개 중 3개
    • Unscrew the two 5.6 mm Phillips screws that secure the fan.
    • Disconnect the fan cable connection.
    • Remove the fan.
  17. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: 17 단계, 이미지 1개 중 1개
    • Remove the one 4.5 mm Phillips screw holding the motherboard to the laptop frame.
  18. Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: 18 단계, 이미지 2개 중 1개 Acer Aspire 3 A315-24P-R7VH Motherboard Replacement: 18 단계, 이미지 2개 중 2개
    • Gently lift the motherboard up and out of the chassis.
결론
작성자
5다른 기여자 명과 함께
Carlos
회원 가입일: 09/14/23
121 평판
안내서 1개를 작성함
Gateway, Team 1-1, Pee Fall 2023 Gateway, Team 1-1, Pee Fall 2023 회원
GCC-PEE-F23S1G1
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 75
전체 시간: 1,657
