주요 콘텐츠로 건너뛰기
Acer Aspire 3 A315-24P-R7VH SSD Replacement
필요한 것
  1. Acer Aspire 3 A315-24P-R7VH SSD Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    • Power off the machine and unplug it from the wall charger.
  2. Acer Aspire 3 A315-24P-R7VH SSD Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire 3 A315-24P-R7VH SSD Replacement: 2 단계, 이미지 2개 중 2개
    • Close the laptop and flip it over.
    • Remove the eleven 6.5 mm Phillips screws from the lower case.
  3. Acer Aspire 3 A315-24P-R7VH SSD Replacement: 3 단계, 이미지 1개 중 1개
    • Insert an opening pick between the lower case and chassis.
    • Pry around the entire perimeter until the lower case releases.
    • Remove the lower case.
  4. Acer Aspire 3 A315-24P-R7VH SSD Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    • Optional: Put on an anti-static wrist strap. Ground yourself by connecting the metal clip at the end to any unpainted metal surface outside of the laptop.
  5. Acer Aspire 3 A315-24P-R7VH SSD Replacement, SSD: 5 단계, 이미지 1개 중 1개
    • Unscrew the one 2.2 mm Phillips head screw that secures the SSD.
    • The SSD will lift to a slight angle.
  6. Acer Aspire 3 A315-24P-R7VH SSD Replacement: 6 단계, 이미지 1개 중 1개
    • Gently grasp the drive and pull it directly out of its socket.
  7. Acer Aspire 3 A315-24P-R7VH SSD Replacement: 7 단계, 이미지 1개 중 1개
    • Double check and make sure the replacement SSD is 2280 in size.
결론
작성자
3다른 기여자 명과 함께
Oswaldo
회원 가입일: 09/07/23
97 평판
안내서 1개를 작성함
Gateway, Team 1-1, Pee Fall 2023 Gateway, Team 1-1, Pee Fall 2023 회원
GCC-PEE-F23S1G1
4 회원들
안내서 6개를 작성함
2가이드 댓글
what is the maximum storage it can support? I wanna upgrade to a 2tb ssd
Duran Victor - 답글
is there one ssd for the storage and one for the windows boot? I just dont want to have to do a new windows install
Cameron Treinen - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 17
지난 30일: 90
전체 시간: 2,600
