주요 콘텐츠로 건너뛰기
Acer Aspire 3 A315-24P-R7VH Speaker Replacement
필요한 것
  1. Acer Aspire 3 A315-24P-R7VH Speaker Replacement, Lower Case: 1 단계, 이미지 1/1
    • Power off the machine and unplug it from the wall charger.
  2. Acer Aspire 3 A315-24P-R7VH Speaker Replacement: 2 단계, 이미지 1/2 Acer Aspire 3 A315-24P-R7VH Speaker Replacement: 2 단계, 이미지 2/2
    • Close the laptop and flip it over.
    • Remove the eleven 6.5 mm Phillips screws from the lower case.
  3. Acer Aspire 3 A315-24P-R7VH Speaker Replacement: 3 단계, 이미지 1/1
    • Insert an opening pick between the lower case and chassis.
    • Pry around the entire perimeter until the lower case releases.
    • Remove the lower case.
  4. Acer Aspire 3 A315-24P-R7VH Speaker Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • Optional: Put on an anti-static wrist strap. Ground yourself by connecting the metal clip at the end to any unpainted metal surface outside of the laptop.
  5. Acer Aspire 3 A315-24P-R7VH Speaker Replacement, Speaker: 5 단계, 이미지 1/2 Acer Aspire 3 A315-24P-R7VH Speaker Replacement, Speaker: 5 단계, 이미지 2/2
    • Find the speakers at the bottom left and right corners of the laptop.
  6. Acer Aspire 3 A315-24P-R7VH Speaker Replacement: 6 단계, 이미지 1/1
    • Unplug each speaker carefully.
    • There are no screws holding the speakers in place, so once unplugged, lift them out.
  7. Acer Aspire 3 A315-24P-R7VH Speaker Replacement: 7 단계, 이미지 1/2 Acer Aspire 3 A315-24P-R7VH Speaker Replacement: 7 단계, 이미지 2/2
    • Plug in the new speaker and place it in the corner that correlates to its shape. The speaker that is to go to the left corner of the laptop will be labeled with an L, likewise the speaker for the right will be labeled with an R.
결론
AlexHarpring
회원 가입일: 09/07/23
301 평판
안내서 3개 작성하였습니다
Gateway, Team 1-1, Pee Fall 2023 Gateway, Team 1-1, Pee Fall 2023 회원
GCC-PEE-F23S1G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 17
전체 시간: 74
