주요 콘텐츠로 건너뛰기
Acer Aspire 3 A315-58-350L Battery Replacement
필요한 것
  1. Acer Aspire 3 A315-58-350L Battery Replacement, Lower Case: 1 단계, 이미지 1/2 Acer Aspire 3 A315-58-350L Battery Replacement, Lower Case: 1 단계, 이미지 2/2
    • Remove the eleven 7 mm Phillips screws that secure the lower case.
  2. Acer Aspire 3 A315-58-350L Battery Replacement: 2 단계, 이미지 1/3 Acer Aspire 3 A315-58-350L Battery Replacement: 2 단계, 이미지 2/3 Acer Aspire 3 A315-58-350L Battery Replacement: 2 단계, 이미지 3/3
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry along the perimeter until the lower case releases.
    • Lift off the lower case.
  3. Acer Aspire 3 A315-58-350L Battery Replacement, Battery: 3 단계, 이미지 1/2 Acer Aspire 3 A315-58-350L Battery Replacement, Battery: 3 단계, 이미지 2/2
    • Remove the two 4 mm Phillips screws that secure the battery.
  4. Acer Aspire 3 A315-58-350L Battery Replacement: 4 단계, 이미지 1/3 Acer Aspire 3 A315-58-350L Battery Replacement: 4 단계, 이미지 2/3 Acer Aspire 3 A315-58-350L Battery Replacement: 4 단계, 이미지 3/3
    • Use tweezers to peel off the black strips of tape on the top of the battery
  5. Acer Aspire 3 A315-58-350L Battery Replacement: 5 단계, 이미지 1/2 Acer Aspire 3 A315-58-350L Battery Replacement: 5 단계, 이미지 2/2
    • Use tweezers to grip the white battery connector and pull it directly out of its motherboard port.
    • Do not pull on the wires.
  6. Acer Aspire 3 A315-58-350L Battery Replacement: 6 단계, 이미지 1/3 Acer Aspire 3 A315-58-350L Battery Replacement: 6 단계, 이미지 2/3 Acer Aspire 3 A315-58-350L Battery Replacement: 6 단계, 이미지 3/3
    • Lift the battery up and out of the chassis.
결론
Evan Sandoval
회원 가입일: 09/11/23
861 평판
안내서 7개 작성하였습니다
Austin Community College, Team 9-1, Watkins Spring 2024 Austin Community College, Team 9-1, Watkins Spring 2024 회원
AUSTINCC-WATKINS-S24S9G1
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 27
전체 시간: 70
