주요 콘텐츠로 건너뛰기
Acer Aspire 3 A315-58-350L Fan Replacement
필요한 것
  1. Acer Aspire 3 A315-58-350L Fan Replacement, Lower Case: 1 단계, 이미지 1/2 Acer Aspire 3 A315-58-350L Fan Replacement, Lower Case: 1 단계, 이미지 2/2
    • Remove the eleven 7 mm Phillips screws that secure the lower case.
  2. Acer Aspire 3 A315-58-350L Fan Replacement: 2 단계, 이미지 1/3 Acer Aspire 3 A315-58-350L Fan Replacement: 2 단계, 이미지 2/3 Acer Aspire 3 A315-58-350L Fan Replacement: 2 단계, 이미지 3/3
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry along the perimeter until the lower case releases.
    • Lift off the lower case.
  3. Acer Aspire 3 A315-58-350L Fan Replacement, Fan: 3 단계, 이미지 1/2 Acer Aspire 3 A315-58-350L Fan Replacement, Fan: 3 단계, 이미지 2/2
    • Use tweezers to remove the black tape that secures the fan cable.
  4. Acer Aspire 3 A315-58-350L Fan Replacement: 4 단계, 이미지 1/2 Acer Aspire 3 A315-58-350L Fan Replacement: 4 단계, 이미지 2/2
    • Remove both of the 4 mm Phillips screws that secure the fan.
  5. Acer Aspire 3 A315-58-350L Fan Replacement: 5 단계, 이미지 1/2 Acer Aspire 3 A315-58-350L Fan Replacement: 5 단계, 이미지 2/2
    • Use tweezers to disconnect the white fan connector from its motherboard socket.
    • Lift the fan up and out of the chassis.
결론
Jesus Salazar
회원 가입일: 01/30/24
100 평판
안내서 1개 작성함
Austin Community College, Team 9-1, Watkins Spring 2024 Austin Community College, Team 9-1, Watkins Spring 2024 회원
AUSTINCC-WATKINS-S24S9G1
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 23
전체 시간: 54
