소개
This step-by- step process demonstrates how to replace a dead or dying battery on your Acer Aspire 3000. It is important to follow the steps carefully in order to prevent damage to the battery ports upon removal. Damage to the ports may cause a bad connection with a replacement battery. Use caution to always remove the battery whenever you are repairing parts of your device.
Begin with the device face down.
Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
다른 2명이 해당 안내서를 완성하였습니다.
