주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Acer Aspire 3000 Hard Drive Replacement
필요한 것
  1. Acer Aspire 3000 Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Begin with the device face down.
    • Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
  2. Acer Aspire 3000 Hard Drive Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire 3000 Hard Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the button found below the battery to the left into the unlocked position.
    • You will know the battery is unlocked if the tab is pushed to the side where the symbol is unlocked.
  3. Acer Aspire 3000 Hard Drive Replacement: 3 단계, 이미지 2개 중 1개 Acer Aspire 3000 Hard Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Locate the battery and the tab to the right of it.
    • Pull the tab to the right while simultaneously pushing the battery away from you.
    • Make sure you push the battery only when tab is held in the right position in order to avoid damage to the device.
  4. Acer Aspire 3000 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1개 중 1개
    • Unscrew the two 4.6 mm Phillips #1 screws on the left side of the hard drive panel in the lower right corner on the back of the laptop using the phillips head j1 bit.
  5. Acer Aspire 3000 Hard Drive Replacement: 5 단계, 이미지 3개 중 1개 Acer Aspire 3000 Hard Drive Replacement: 5 단계, 이미지 3개 중 2개 Acer Aspire 3000 Hard Drive Replacement: 5 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool under left side of the hard drive cover and gently pry the cover open.
    • Pull the cover up and out to release the tabs on the right side of the cover and remove from the device.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Courtney Lyons
회원 가입일: 10/30/16
199 평판
안내서 1개를 작성함
Baylor, Team 4-2, Williams Fall 2016 Baylor, Team 4-2, Williams Fall 2016 회원
BU-WILLIAMS-F16S4G2
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 39
전체 시간: 2,600
