주요 콘텐츠로 건너뛰기
Acer Aspire 3000 Keyboard Replacement
필요한 것
  1. Acer Aspire 3000 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Begin with the device face down.
    • Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
  2. Acer Aspire 3000 Keyboard Replacement: 2 단계, 이미지 1/2 Acer Aspire 3000 Keyboard Replacement: 2 단계, 이미지 2/2
    • Slide the button found below the battery to the left into the unlocked position.
    • You will know the battery is unlocked if the tab is pushed to the side where the symbol is unlocked.
  3. Acer Aspire 3000 Keyboard Replacement: 3 단계, 이미지 1/2 Acer Aspire 3000 Keyboard Replacement: 3 단계, 이미지 2/2
    • Locate the battery and the tab to the right of it.
    • Pull the tab to the right while simultaneously pushing the battery away from you.
    • Make sure you push the battery only when tab is held in the right position in order to avoid damage to the device.
  4. Acer Aspire 3000 Keyboard Replacement, Keyboard: 4 단계, 이미지 1/1
    • Lift the laptop to be on its edge, with the bottom of the screen in the air.
  5. Acer Aspire 3000 Keyboard Replacement: 5 단계, 이미지 1/1
    • Remove the three 4.6 mm Phillips #1 screws that are on this edge.
  6. Acer Aspire 3000 Keyboard Replacement: 6 단계, 이미지 1/2 Acer Aspire 3000 Keyboard Replacement: 6 단계, 이미지 2/2
    • Wedge a spudger into the latch on the right side.
    • Open the lid completely to facilitate removal.
    • Pull the handle of the spudger towards you to pop the first of the tabs that hold this piece in place.
    • Starting from right to left, pop the remaining tabs by lifting up on the panel and rotating the panel to the left.
  7. Acer Aspire 3000 Keyboard Replacement: 7 단계, 이미지 1/1
    • Unscrew the two 4.6 mm Phillips #1 screws.
  8. Acer Aspire 3000 Keyboard Replacement: 8 단계, 이미지 1/1
    • Gently lift the top edge of the keyboard out of its place.
    • Do not completely remove the keyboard as there is still a ribbon cable connecting it to the device.
  9. Acer Aspire 3000 Keyboard Replacement: 9 단계, 이미지 1/1
    • Lift the ZIF connector's black retaining flap. Then gently slide the ribbon cable out.
    • Remove the keyboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Lykia Harper
회원 가입일: 10/29/16
258 평판
안내서 2개 작성하였습니다
Baylor, Team 4-2, Williams Fall 2016 Baylor, Team 4-2, Williams Fall 2016 회원
BU-WILLIAMS-F16S4G2
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 771
