주요 콘텐츠로 건너뛰기
Acer Aspire 3000 RAM Replacement
필요한 것
  1. Acer Aspire 3000 RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Begin with the device face down.
    • Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
  2. Acer Aspire 3000 RAM Replacement: 2 단계, 이미지 1/2 Acer Aspire 3000 RAM Replacement: 2 단계, 이미지 2/2
    • Slide the button found below the battery to the left into the unlocked position.
    • You will know the battery is unlocked if the tab is pushed to the side where the symbol is unlocked.
  3. Acer Aspire 3000 RAM Replacement: 3 단계, 이미지 1/2 Acer Aspire 3000 RAM Replacement: 3 단계, 이미지 2/2
    • Locate the battery and the tab to the right of it.
    • Pull the tab to the right while simultaneously pushing the battery away from you.
    • Make sure you push the battery only when tab is held in the right position in order to avoid damage to the device.
  4. Acer Aspire 3000 RAM Replacement, RAM: 4 단계, 이미지 1/1
    • Unscrew the two 4.6 mm Phillips #1 screws found at the bottom of the RAM cover using the phillips head j1 bit.
  5. Acer Aspire 3000 RAM Replacement: 5 단계, 이미지 1/1
    • Open the RAM cover by wedging the opening tool and the metal spudger in the opening between the two screws.
  6. Acer Aspire 3000 RAM Replacement: 6 단계, 이미지 1/1
    • Slide the opening tool around the sides of the cover to release the 3 tabs that hold the cover down.
  7. Acer Aspire 3000 RAM Replacement: 7 단계, 이미지 1/1
    • Lift and pull the cover back towards you to detach it from the device.
  8. Acer Aspire 3000 RAM Replacement: 8 단계, 이미지 1/1
    • Push the white tabs on either side away from the from the chip.
    • The chip should be released upward automatically after pushing the tabs.
  9. Acer Aspire 3000 RAM Replacement: 9 단계, 이미지 1/1
    • Pull and lift the chip to release it from the RAM port.
  10. Acer Aspire 3000 RAM Replacement: 10 단계, 이미지 1/1
    • Repeat step 9 to release the bottom chip from its RAM port.
결론
다른 2명이 해당 안내서를 완성하였습니다.
roro6730
회원 가입일: 10/30/16
351 평판
안내서 2개 작성하였습니다
Baylor, Team 4-2, Williams Fall 2016 Baylor, Team 4-2, Williams Fall 2016 회원
BU-WILLIAMS-F16S4G2
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 10
전체 시간: 684
