주요 콘텐츠로 건너뛰기
Acer Aspire 3000 Wireless Card Replacement
필요한 것
  1. Acer Aspire 3000 Wireless Card Replacement, Battery: 1 단계, 이미지 1/1
    • Begin with the device face down.
    • Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
  2. Acer Aspire 3000 Wireless Card Replacement: 2 단계, 이미지 1/2 Acer Aspire 3000 Wireless Card Replacement: 2 단계, 이미지 2/2
    • Slide the button found below the battery to the left into the unlocked position.
    • You will know the battery is unlocked if the tab is pushed to the side where the symbol is unlocked.
  3. Acer Aspire 3000 Wireless Card Replacement: 3 단계, 이미지 1/2 Acer Aspire 3000 Wireless Card Replacement: 3 단계, 이미지 2/2
    • Locate the battery and the tab to the right of it.
    • Pull the tab to the right while simultaneously pushing the battery away from you.
    • Make sure you push the battery only when tab is held in the right position in order to avoid damage to the device.
  4. Acer Aspire 3000 Wireless Card Replacement, Wireless Card: 4 단계, 이미지 1/1
    • Remove the two 4.6 mm Phillips #1 screws on the lower edge of the laptop case.
  5. Acer Aspire 3000 Wireless Card Replacement: 5 단계, 이미지 1/1
    • Pop the three side tabs out of the back case.
  6. Acer Aspire 3000 Wireless Card Replacement: 6 단계, 이미지 1/1
    • Remove the panel that covers the graphics card.
  7. Acer Aspire 3000 Wireless Card Replacement: 7 단계, 이미지 1/1
    • Remove the black and white cables attached to the graphics card.
    • Be careful to lift vertically as to not mess up either part of the connectors.
  8. Acer Aspire 3000 Wireless Card Replacement: 8 단계, 이미지 1/1
    • Push the white flanges on either side of the graphics card out.
    • The card should lift on its own slightly out of the case.
  9. Acer Aspire 3000 Wireless Card Replacement: 9 단계, 이미지 1/1
    • Remove the card by lifting up and away from the edge that has all of the contacts on it.
결론
Lykia Harper
회원 가입일: 10/29/16
258 평판
안내서 2개 작성하였습니다
Baylor, Team 4-2, Williams Fall 2016 Baylor, Team 4-2, Williams Fall 2016 회원
BU-WILLIAMS-F16S4G2
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 946
