이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Begin with the device face down.
Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
Slide the button found below the battery to the left into the unlocked position.
Locate the battery and the tab to the right of it.
Pull the tab to the right while simultaneously pushing the battery away from you.
Remove the two 4.6 mm Phillips #1 screws on the lower edge of the laptop case.
Remove the card by lifting up and away from the edge that has all of the contacts on it.
